7A fuel regulator question.
  • jsol
    • Jul 2011
    • 353
    • Country: Australia
    Just wondering if you can use the 4 bar fpr out of v6 c4/b4 on the 7A engine. I know they are a drop in type. I have used a spare rail and rigged myself a solution. My main concern is the 7A needs 4.2 bar at WOT. I have tried the 4 bar fpr but the car feels a little flat up top. Other wise would a 4.5 bar fpr be the way to go?
    I’ve heard it said that if you have a way to measure the pressure, you can raise the pressure from 4 Bar to 4.2 by squeezing the FPR in the vice with a ball bearing on top. I’ve not tried this myself though!
      The 7A FPR (a 054 133 534) is supposed to be an odd-man out 4.5 Bar unit, so you shouldn't use a 4.0 Bar. I understand that some 1.8T engines used a 5.0Bar FPR.
      Some Fuel Pressure Regulator info:
      • jsol
        • Jul 2011
        • 353
        I'll get a 4.5 bar drop in fpr as with the 4 bar one it is not running properly. I'll give the ol ballbearing trick a go before I change it to see if it does make a difference.
        • jsol
          • Jul 2011
          • 353
          On the main crank breather hose (the elephant trunk) there is a tee leading somewhere else. Where?. Mine does not have this tee.
          • Quattro Driver
            • Oct 2010
            • 30
            I have 7A fpr in stock if needed
            • Bowie69
              • Nov 2013
              • 2675
              In think that T is blocked off with a cap.
              • John.
                • 2615
                Looks like it, that pipe is metal too as opposed to rubber type so maybe it's suitable for more than one engine type?
                • Mikes2
                  • 1704
                  On mine, that T has a line running to the throttle body
                  Mike
                  http://www.s2-audi.co.uk
                  • jsol
                    • Jul 2011
                    • 353
                    Yes looks like there are two versions
                    • Bowie69
                      • Nov 2013
                      • 2675
                      Yep, there are two versions, the hitachi ISV/banana manifold version, and the later Bosch ISV/cast manifold, I have the later engine but with bunch of bananas, bosch ISV and I think a blocked off port.
                      ETKA/parts manuals diagrams here are very unhelp[ful, the pictures don't match the vacuum or breather line arrangements at all.
                      • steve briance
                        • Aug 2014
                        • 1455
                        that ETKA image won't look like your 7A as it doesn't like it is the right engine at all to me!
                        That T connection does indeed go off to the throttle body or, the rubber hose between the ISV and inlet manifold if you have the Bosch ISV. I can't remember which as mine has long since had crank breathing through a can and that pipe isn't connected.
                        The 'elephant trunk' used to be rubber until the factory upgraded to metal. The original rubber items used to suffer from being soaked with oily fumes and got soft, split just fell to bits.
                        Metal is better. :-)
                        • jsol
                          • Jul 2011
                          • 353
                          Yes, the image looks more something that runs Bosch k jetronic. NG perhaps. I had tp replace the 'trunk' on mine due to it disintegrating.
