Radiator Bleeder
  • Radiator Bleeder
    Anybody know the part number for the sealing washer, cant find it in ETKA, or a replacement that seals properly?
    Cheers,
    Mark
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    Hi Mark,
    I cant remember if you have a plastic rad or one with brass headers on yours. On my S2 (brass tanks on rad) the only thing that would seal was a thin 10mm copper washer that I use for Aeroquip banjo bolts. They are thin enough to crush slightly but I'd only use them once. I can post you a couple if it helps. Pete
      Hi Pete, its the plastic rad i have in mine. The original fiber washer has had enough, i thought i had found some that fitted but they are too thin to seal properly.
        Worth checking but probably the rad has a brass insert? If so you should be fine to use a normal crush washer - I also use a thin copper crush washer on mine
          Copper washer.
          Heat it over the gas till it glows and drop it in a cup of cold water to soften.
            We have fiber washers , copper and aluminium I'll post you a couple of each if you like.hope you sort it soon fella. Regards Lynn
