Convert WR quattro to ABY?
  • Colesy
    • Feb 2009
    • 2980
    I have an almost original WR quattro which was a Cat-d write off in the 90's and has very little history. The odometer was also broken for around 4 years before I bought it (now fixed) so the mileage can't be verified.
    Would I be mad to swap in an ABY engine? - Before anyone asks no I'm not breaking any of my S2's, I have a spare engine.
    I would be mainly be looking to do this for a bit of extra power and reliability. Since I've had the WR it has had starting issues which have been hard to nail down. Rather than spend a wedge at a specialist I was thinking fit an engine and system that I know and gain some performance at the same time.
    From what I've read I could stick with the 5 speed gearbox that's in the car. So it would probably just be a case of swapping over the engine, loom and modifying the speedo etc.
    I wouldn't be going big power so would look to keep the quattro running gear stock.
    Friends have said that modifying an original car would be madness. But as I see it I'd be upgrading it to a much more reliable and desirable engine setup. The Cat-d status and lack of history has already knocked it's desirability for a collector so why not make the most of the car as a car to be driven?!
    I've also seen cars with later engines fitted that are advertised at comparable rates to original cars so would the conversion actually damage it's value?
    Any tips and opinions much appreciated especially as to the complexity of the engine swap which I have probably grossly underestimated the difficulty of!
    This gallery has 1 photos.
  • vonbeck
    • 2455
    get it done if its for you who cares if its not original, if your not in it for the cash, as long as i`m sure it will put a smile on your face!!! enough said
    • irishs2
      • Apr 2009
      • 2455
      You could always keep the old engine and accessories just in case you do intend to sell. Also CAT-D doesn't carry over if the car is exported to , say, Ireland.
      Eric
      95 S2 Avant under rebuild.
      • 4WDrifter
        • Nov 2012
        • 1251
        Go for it! and might as well shorten it too!
        1996 S2 ABY Coupe silver
        2003 S3 8L dolphin grey
        2014 RS4 B8 prism silver
        • fish
          • Aug 2007
          • 2333
          • Home: United Kingdom Current: Sweden
          Go for it. If itsinot a minter to start with, then it will only get better with a 20V.
          Audi 80 Competition -94 Daily driver
          www.garaget.org/fish for more pic´s of my cars
          • Colesy
            • Feb 2009
            • 2980
            I think I'm half convinced! Now to source some of the missing parts... What flywheel and clutch would I need?
              I think 3B or RR
              • varia
                • 821
                • Current: United States
                Ive just installed mine recently, I used 01E 6 speed (from an ABY) 7A flywheel and SPEC clutch kit (SA233F)
                • Colesy
                  • Feb 2009
                  • 2980
                  Originally posted by newsh
                  I think 3B or RR
                  Cheers, reading another thread it sounds like the WR clutch and flywheel will fit but an RR or a 100 turbo flywheel would be better. Will keep digging.
                  http://quattro4life.com/images/silve...415_200238.jpg
                  I read that you have to modify the tunnel if fitting an 01E is that something you did?
                    You don’t have to modify the tunnel if you keep the original 5 speed which is really strong
                    • Colesy
                      • Feb 2009
                      • 2980
                      That was supposed to say 01E have edited now.
                      I think it's sensible to stick with the WR 5 speed, it is quite knotchy though are parts still available? Might get it refurbed when the engine comes out
                      • GT500
                        • Jun 2006
                        • 2181
                        Just weld the trigger pin on your WR flywheel and your sorted. That’s how mine is.
                        Makes it a much better car. Do it!
                        Rob..
                        87 UR 20v ABY
                        97 S6 Avant
