RS2 going back together help/ advice needed!
  • #16
    Yes it is the one on ebay and it does start and go it has also had a rebuilt turbo, recondition head, worsner pistons, new timing belt, new water pump and lots more done its suffering from a misfire any ideas what it may be?
    • #17
      I would check they got the timing correct when they did the cambelt. The RS2 has an unusual mark alignment on the pulley which may have put the belt a tooth out. It was covered in a recent post here. I will have a search for you.
      • #18
        Not sure how to check if the coils are any good, but they do tend to brake down at this age if they still are the originals. TFSI-kit for the win.
        • #19
          Scroll down this page
          https://www.s2forum.com/forum/member...2-94-swe/page6
          andersg is also correct. Error 404 does a high quality coil conversion kit which I have installed and I highly recommend. However, if you decided to stick with original, I have my old coils which are in good working order.
          • #20
            Thank for the input would you go for the after market coil does it perform better than the OEM coil?
            • #21
              Forgot to ask who supplies the TFSI coil ki/?
              • #22
                Error 404 here does the kit. Send him a pm. https://www.s2forum.com/member/4880-error404
                It allows you to use individual coil packs found on newer Audi's (TSFi).
                • #23
                  Hi Dave
                  What part number should I ask for for the TFSi coil kit? thanks for the photo very helpful thanks
                  • #24
                    Originally posted by joss01 View Post
                    Hi Dave
                    Speak to Error as he knows exactly what you need. I bought some second hand coil pencils on ebay from a 2.0tsfi but had to cut the rubber insulator slightly so they fit properly. I seem to remember Beru ZSE032 being recommended but check with Alex (Error)
                    • #25
                      thanks Alex
                      • #26
                        Before you go throwing loads of money at it I would check the timing, as mentioned earlier, plus do a full compression check on all cylinders to determine if all is good. Then start the elimination process of the coils, swap them round to pin point which one is the issue before you go to buy a full set.
                        I would have thought the place you've bought it from would have done this before they gave up on it.
                        • #27
                          Yes sound advice thanks
                          • #28
                            While I am here I am looking for some parts as shown in the photo can someone give me any advice where I can find them.
                            This gallery has 1 photos.
