to get rid of the maf
  • volcano rs
    • Jun 2005
    • 2265
    anyone know if its possible to get rid of the maf and use some sort of air sensor to replace it with .
    that way you won't have to keep cleaning the thing .
    surely there must be a way .how do after market ecu,s solve this problem ?
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    from what i know of,any kind of aftermarket ECU can get rid of the maf,since it is replaced by map sensor.
    VEMS is one that connects easily to the audi ecu connector
      I have never cleaned my maf and it looks bright as a button, I sugest your maf is not cleaning itself.
      • volcano rs
        • Jun 2005
        • 2265
        i don't have a problem with my maf yet i just want to get rid of it if i can and make the car more reliable
          Ah, ok
          I heard there was a tuner, in this country I think, who maps Motronic useing the TPS instead of the Maf as a variable, so you get a throttle pedal that feels more like carbs, I'd like to try this myself but I don't know who it is that does it.
          • quattronutter
            • Jan 2005
            • 690
            can map using the tps or map sensor as stated above,i used a tps to map my mk1 16v on twin webbers
            • volcano rs
              • Jun 2005
              • 2265
              some clever person on here should know if this is possible it will save everybody a lot of trouble and money
              • robo
                • Aug 2004
                • 2086
                Not only trouble and money but also extra two strait conectors and some more space under bonnet.
                sigpic_________
                Rob
                • volcano rs
                  • Jun 2005
                  • 2265
                  so if you have a seperate map sensor could that work ?.
                  whatever it is it only needs to measure volume of air . so there must be some sort of sensors available to do this job .
                    No, IIRC you just dont bother to measure the mass of air, you map it to the TPS instead. OK for a track car, spending a lot of time at WOT, maybe a bit juicy for a daily driver?
                    • volcano rs
                      • Jun 2005
                      • 2265
                      so some sort of sensor after the intercooler to measure the volume is the way to go for every day use. come on you electronic wizards where are you ?
                        But this is what is so clever about the MAF it measures the Mass Air Flow, ie the weight of air passing through, so it automatically know that there's more oxygen in the air when its colder/denser. Just measuring the volume of air , like a mechanical CIS system and throwing in the fuel to match is not nearly as clever. You'd be going back in time. Simple aftermarket systems do without a MAF by guessing the air mass based on signals from the TPS (throttle opening) MAP sensor (manifold pressure/vacuum) and air temperature I believe. But I'm no expert by any means, its a shame Mihnea doesn't come here much any more.
                        • volcano rs
                          • Jun 2005
                          • 2265
                          i know what you are saying john .i'm sure there is some sort of sensor out there that would do the same job as maf .what i'm saying is could some sort of sensor be added to our ecu internally or externally to do the job of the maf ?
                          • volcano rs
                            • Jun 2005
                            • 2265
                            i don't think the maf measures the tempreture of air .i thought the water tempreture sensor determined when more fuel was required and gave the ecu the signal to rich and lean when it was cold .i'm cr*p at electrics
                            • dest
                              • 4287
                              I know Gotech does away with the MAF and some other sensors and various bits of vacuum pipe work.
                              If you want more info etc Id give Jamie or Mark at Jamsport a call, they are the main uk dealers in Northampton 01604 755529 (Tell him Martyn sent you )
