How much does your S2 weigh?
  • K Simmonds
    • Dec 2007
    • 7627
    Originally posted by anton
    i believe its been posted before as a 20kg difference.
    Ant
    Thanks, that's not to bad but 20kg's is well worth saving especially at the front, my aim is not only to reduce the over all mass but to try and improve the front to back distribution as much as I can. I suppose when used with a duel mass fly wheel the weight penalty is higher. Think I'll try and stick with a fiver speed box but hang on to the six speed just in case the five speed doesn't hack it.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • anton
      • Jan 2005
      • 802
      you can always loose the spacer and run a single mass flywheel, if your on a 3b you can always put the battery in the boot, thats 20kg off the front and 20kg onto the backso 40kg difference to front/rear balance....
      Ant
      91' Coupe quattro 20v - project
      KW V2s and other goodies
      now gone
      03' BMW 330CI - Sold
      08' A5 Coupe 3.0l tdi quattro - Sold
      57' BMW 525d M Sport Touring
      • A80Avant
        • 10873
        • Country: Greece
        my weight is without me in it.With me it goes to 1780 to 1790Kg
        • AUDIS2avant
          • Jan 2009
          • 670
          • Country: Denmark
          Ok, theese cars are heavy then
          Had mine on a freight weight today, and it weighs 1600kg with 10 fuel in the tank, spare wheel and tools but without me
          Not to bad then
          • K Simmonds
            • Dec 2007
            • 7627
            Ant
            Battery tray already removed and the battery is going in the spare wheel well to get it as back as safely possible, don't like the idea of sticking it in the hole right at the back of the boot as in the event of a heavy rear end it will end up in the petrol tank, I'm even going to remove the procon 10.
            1994 MTM RS2.
            2000 B5 TQS.
            • stiglet
              • Aug 2007
              • 1264
              Thats a good idea actually. I was thinking the little bucket thing on the drivers side, but the S/W well is ideal. Will a battery fit though?
                Battery box mounted behind the passenger seat on the floor?
                • stiglet
                  • Aug 2007
                  • 1264
                  Yep that's another possiblity, but the further back the better
                  • Puglife
                    • Jun 2006
                    • 731
                    And yet the WR engine UR is only 1300kg and i'm hoping to get mine down to 1000kg
                    Jay - pug_life85@hotmail.com
                    1986 Audi UR quattro - WORK IN PROGRESS
                    1981 VW Mk1 Golf - "20v Jim, but not as we know it!"
                    • K Simmonds
                      • Dec 2007
                      • 7627
                      I looked at the bucket thing as well, but without cutting the car about you can only fit a piddly little battery in there and it's still perilously close to the petrol tank IMO.
                      The spare wheel well is perfect, there's enough room to mount an Avant battery tray in there tidily and fit a decent size battery without it being higher than the level of the boot floor, which I will make level all the way across. There would also be enough room in there for a small 12v compressor and two bottles of tyre sealant. I'm going to ditch the spare wheel as a 17"x8" wheel doesn't fit in a satisfactory manner anyway.
                      1994 MTM RS2.
                      2000 B5 TQS.
                      • Nero
                        • 347
                        I had my 3b (aircon, non sliding roof) on a weight on my work.
                        With a full tank, no spare tyre, no rearseat, only 2 speakers in the front, cats fitted, 18 inch wheels and a RS2 ic it was 1440 kg / 3175 lbs. No persons in it.
                        So it's still a long way to reach 1300 kilo...
                        www.S2power.com
                        S2 Coupe - decat - EPS exhaust - RS2 IC - RS2 front - RS2 brakes - RS2 mirrors - Koni shocks - H&R springs - Jehnert doorpanels & Audison Amps - leather & sunroof - VEMS - USA rearlights
                        • Albert
                          • 1500
                          • Country: Poland
                          #27
                          1198 kg ~ 2 641 lbs
                          RS2 gearbox weights 72kg no oil
                          AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
                          • bluequattro
                            • 2960
                            My coupe is around 1100kg
                            No rear seats,
                            lightweight front seats
                            fiberglass panels
                            all sound deadening carpets that thick bitumen underseal all gone, battery behind seats
                            lightweight boot floor
                            next to have plastic windows and I may try to get some door skins/bonnet made in thin alloy
                            I just need to loose 50kgs myself and it ll be a really fast car!
