ABY Dipstick oil leak
  • mcandmar
    • Apr 2004
    • 5118
    This is the second ABY motor i have found this problem so thought it was worth a mention.
    The dipstick tube has a small rubber seal where it joins onto the block, part number N90461401. The first ABY i dismantled was missing the seal which i later found inside the sump. And when i was cleaning the S2 motor i noticed the block was covered in oil around the hole. Sure enough when i removed the dipstick tube i found the remains of a mangled seal in there. Worth checking if your working in that area
    I have a new one somewhere so when i find it i'll post up measurements.
    Mark.
    91CQ20v - Gone to a new home
    93UR-S4 - The Magic Carpet
    94S2Bus - The Emerald Express
    does it just slot in Mark?
      My engine out the Avant didn't have one the stroker came with a seal on the dipstick
        Nice one,
        thanks Mark.
        • GazzaG60
          • 4133
          that explains that leak then.
          • mcandmar
            • Apr 2004
            • 5118
            Found it, ID is 9.5mm and about 2.5mm thick. Having said that i think its too big for the job.
            For the first attempt i slid it onto the dipstick tube and found there was no way it was ever going to slide inside the hole. Second attempt i pushed it down inside the hole and found there was no way the tube was ever going to fit in. Third attempt i crushed it between the tube and block at the very top.
            If i had a box of o-rings to play with i would have used too, one slightly smaller to fit down inside the hole, then another at the top like i ended up doing. Either way its sealed so job done.
            Mark.
            • SteveH
              • 4460
              Does anyone know whether the piece which protrudes from the block, to attach the dipstick tube into is removable? If so, does anyone have one they can take a picture of and provide measurements? I think I may need one of these for a block I'm using for a rebuild, but can't find a part number for it. Parts album shows it as included with the block.
              91 Modded 3B
              14 A6 Avant Black Edition
              • rxl
                • 1913
                Don't have measurements for these as I sold them to forum users
                This gallery has 1 photos.
                • SteveH
                  • 4460
                  Thanks. I need this piece which doesn't appear to be available as a replacement part. I guess I'm looking for someone who has a damaged block, who will sell this part. Or someone who has one that I can make a copy from
                  91 Modded 3B
                  • SteveH
                    • 4460
                    Part No 30 which I can't find a part number for. Any ideas, #30 doesn't show on any of the family albums I can find online..
                    91 Modded 3B
                      Is it screwed in or pressed in?
                      I have a spare bottom end I could borrow it from for you but can’t see how it comes out.
                      • SteveH
                        • 4460
                        There's no screw thread in the block, so I assume it's a press fit. Never removed one.
                        91 Modded 3B
                          Steve I have a scrap AAN block which I will remove it from for you - its away being hot tanked at the moment. Once its back I'll get it out for you - it's just pressed in.
                          I'll also model it so I can make some replacements.
                          Alex
                            • SteveH
                              • 4460
                              Alex
                              That would be great
                              91 Modded 3B
