Audi Tt Injectors
  • T2Andy
    • 1903
    Audi Tt Injectors
    After some reserch and asking differant tuners ive been told i can use the new AUDI TT injector,they are 357cc high impedance ,they are cheaper than the rs2 injector
    and are the latest injector design ,ive been told that the RS2 is old tech compared
    so the TT ones flow patern and delivery is much better ,any views on this before i buy cheers
    First find the actual impedance of these TT items - different folk have varying views on what the term as 'high impedance' - lets be talking ohms here.
    Whatever injectors you get have to -
    a - fit in the hole
    b - fit onto the fuel rail
    c - accept the 2-pin connector
    d - have the right impedance for matching the ECU expectations
    e - have a suitable spray pattern... some injectors have specific oddball patterns for some engines - dunno if that is try of these TT ones
    Paul
    • GazzaG60
      • 4133
      why rs2 injectors?
      why not just bosch whatever size.
      rs2 = overpriced.
      read this. http://www.usrallyteam.com/index.php...ex&cPath=10_44
      it will explain injectors and give you an idea of costs. i usually avoid over inflated uk prices.
      buts some with a decent overhead andy. that will be a waste getting those.
      • nip
        • Apr 2006
        • 1786
        • Home: United Kingdom Current: Abu Dhabi
        alright andy why not use siemens 440cc injectors, i might be able to get a set if ur interested
        • T2Andy
          • 1903
          nice mate let me know
          • T2Andy
            • 1903
            Thanks i will get some more info on these ,i def need some lager ones as mine are gasping
            • nip
              • Apr 2006
              • 1786
              il find out sunday mate, il keep ya posted
              • Jonas_R
                • 3781
                • Country: Denmark
                Get these they can fuel a bit more then the RS2 injectors but are why cheaper. I got mine of this ebay seller.
                Ebay link
                Sleeper S2 Avant +450
                A6 Avant 2.7t Stage 3
                Audi S2 Coupe RS2'ed
                • T2Andy
                  • 1903
                  They look perfect
                  • europeanme
                    • Oct 2005
                    • 3817
                    you can use mine and see how you get on with RS2 ones...I'll not be needing them for a while....
                      Try to get something spec'd for as close to 360ccpm at 3bar so as to make life easier on RS2 based chipsets.
                      I'm working on a variant that runs with 440ccpm but need realtime AFR data from the real world to get it right.
                      To ensure you have good options with fuel injector choices I strongly advise a variable FPR - say from 3 to 5 bar range... Its all meaningless unless you have wideband AFR to see WTF is going on anyway.
                      • T2Andy
                        • 1903
                        Thanks mate i will let you know ,might have some be end of week cheers
                        • T2Andy
                          • 1903
                          Thanks paul .
