My son has been having problems with his Golf. I've just had a bit of a look and its quite weird, he's been having flat battery issues and his driver's door would not unlock either with the alarm fob or the key even though the button on the door is going up and down. With the battery disconnected however, the door unlocks which seems to indicate that the mechanism is ok. With the battery connected, if you turn the key in the door to unlock and hold it there the other 3 windows in the car open
I've had the door card off and nothing seems to be amiss but I guess there could be something broken.
Before we start pulling the the dash out and try to trace and remove the alarm system does anone have any pointers or experience to share on this?
TIA!
TIA!
Don't want to go buying a new motor only to find it doesn't fix the problem..
