How to transport an engine
  • andy10v
    • 5996
    Originally posted by sidrick
    Engine is now out and in my garage.- Never build a cheap engine crane without instructions again.
    Sold ABY-stock
    • sidrick
      • Jan 2011
      • 1342
      Originally posted by andy10v
      Well this is the e-mail I sent to the seller:
      'Hello,
      I don't intend to leave negative feedback since the item was cheap (which should have been indicative of poor quality) and the delivery time/service was excellent, but I'm writing to let you know that the item was extremely poor quality.
      - The instruction 'diagram' detailed using part numbers 16-20, but the part description listing stopped at 15.
      - Of the 8 threaded castor bolt holes, 4 spun their threads with little more than hand-tight pressure.
      - 2 of the small castor bolts sheared with very little pressure.
      Due to the above the castors are not completely secured and I wouldn't be confident using the lift until the holes are re-tapped or the castor mounts welded to the frame.
      As mentioned, I was pleased with the quality of service, but the quality of product would stop me buying from your store again.
      Regards,
      Scott.'
      In fairness, he's come back and been great (offered replacement parts F.O.C.), but there's not much you can do about poor manufacturing and threaded bolt holes. Even if they're re-tapped I don't trust the metal enough, so shall arrange for the castor mounts to be welded to the frame.
      • martinws
        • Oct 2008
        • 917
        Lucky you sheered the bolts etc before you used the thing. Shame you were not further south or you could have borrowed my crane.
        • sidrick
          • Jan 2011
          • 1342
          Weyhey:
          These are the trim pieces I need if anyone has them in black:
          Along the top of the window (window firm broke this...):
          The lower piece which goes right along and covers the boot lock:
            Oh dear. These are NLA for sure and rare in black
            • andy10v
              • 5996
              Good stuff.
              If the window firm broke it surely they have to sort it?
              Sold ABY-stock
              • S2TORNADO
                • Jan 2008
                • 620
                the long trim around the boot lock is pretty much standard in black. i think i've got a good one here put you should be able to find one closer to home.
                tailgate trim in black could be more of a problem.
                maybe best to get a set of four beige or grey tailgate trims, plastic prime first then satin black them. that should be a good match and the paint will stay on as they don't really suffer wear.
                keep your black ones safe and you may match the damaged piece in the future.
                • TimE-J
                  • Jul 2009
                  • 1292
                  If its just the clip mounts on the top boot piece could they not either be glued or plastic welded back on?
                  96 S2 aby Coupe. Rebuild Project
                  96 mk3 golf tdi daily.
