throttle cable required asap
  • quattroamm
    • Dec 2003
    • 306
    I've got a 90 quattro with aby engine and Wagner inlet manifold. What throttle cable are people using or how do i extend the original one. I've searched previous threads but still no definitive answer.
    1991 90 quattro 20v sport 450 bhp
    Rs2 engined ur quattro sold
    11 golf tdi
  • quattroamm
    • Dec 2003
    • 306
    anyone
    11 golf tdi
    • andyg plym
      • Nov 2006
      • 4646
      if you need an aby one i have a spare,but think you will probably need a longer one
      check s2_bo he did a write up on his with the same mani you have
        I bought a universal cable but ended up only using the inner which I threaded through from the pedal end. I then used a short section of outer to extend to the new TB position and attached the nipple from the old cable with a cable joiner. It's been working fine for a while now.
        • bikerjim
          • Feb 2008
          • 1028
          What does the cable joiner look like?
          • quattroamm
            • Dec 2003
            • 306
            can you tell me where you got the cable from
            11 golf tdi
              Electrical "choc block" with the plastic cut off Make sure you feed the cable through both the screws from opposite ends.
              • bikerjim
                • Feb 2008
                • 1028
                Ahh i see, thanks
                  This'll work
                  • kat1127
                    • Oct 2008
                    • 18
                    eeh
                    what tyhe f++
                      http://www.ebay.co.uk/itm/UNIVERSAL-...item20c421ecb9
                      • QuattroFever
                        • May 2006
                        • 1360
                        That is exactly what I have done!
                        I used a teflon coated bicycle cable Halfords etc...
                        Volcano ABY coupe
                        Ant
                        • QuattroFever
                          • May 2006
                          • 1360
                          be careful. the brass bit with the screws in chews away at the plastic on the throttle.
                          You need a bead with a hole down the middle to make it seat properly. Like a rubber bead used in fishing or a small ball ledger.
                          Volcano ABY coupe
                          Ant
                          • twenty valve
                            • Oct 2010
                            • 630
                            PERFORMANCE INTAKE MANIFOLD FOR AUDI 5 CYL. 20V TURBO S2 / RS2
                            Wagner Tuning Aluminum Cast intake manifolds are CAD Designed and Flow Optimised for each vehicle to produce the ultimate in horsepower and torque from your vehicle.
                            Constructed of 8.5 lbs. of high grade AlSiMg11 cast aluminum and then CNC machined to our exacting specifications, each manifold is a performance work of art.OEM+ Fit and finish for easy installation.
                            The Intake comes with a special Surface treatment, wich is equal to the new TTRS Intake Manifold.
                            The Wagner Tuning Intake manifold features:
                            •Lower air temperature
                            •Increased throttle response
                            •smaller size when installed allows for larger intercoolers
                            •tuned intake pulse reduces throttle body valveflutter
                            •Optimized airflow allowing for increased cylinder fill during intake cycle.
                            For ABY to ADU code engines a modified servo pump bracket is required.
                            As the Throttle body location has been relocated to the front of the engine compartment, you must use the OEM Audi throttle cable part #893721555R.
                            All connectors for vacuum and other ports are preinstalled using high grade steel hardware and fittings.
                            Custom mounting of the vacuum and other ports are available (if feasible). (Please put your request in the notes field of your order)
                            The intake manifold is delivered ready to install, no more modifications needed.
                              That only applies to LHD cars, not RHD
                              There are multiple threads with solutions from lengthening to using a new inner cable
                              Sonic posted the details of the inner cable solution and the part
