I have purchased a dump valve from Dresden in Germany and located the old valve....the recirculating valve under the front right headlamp.
the problem is this.....there are supposed to be three hoses attached and to my shock I could only feel the two bigger ones....the boost pipe has either been removed or has worked itself free,which brings me on to the subject....where the f*ck is the actuator as I was hoping to follow the boost pipe from the valve to find it?!!
I have a coupe Quattro 1990
any help will be greatly appreciated
Thanx
Thanx
