RS2 versus S2 inlet manifold
  • Rikki Kitto
    • Feb 2010
    • 6276
    Just wondered if any engine geeks had views on the technical advantages of RS2 over S2 inlet manifolds.
    I know the RS2 one looks pretty cool what with the inscription but is there a big advantage over the standard S2 unit, to be honest at around 10 times the price it should be quite a spectacular improvement really.
  • andy10v
    • 5996
    Its the same as an ABY with Porsche on it, no performance benefit.
    Sold ABY-stock
    • Rikki Kitto
      • Feb 2010
      • 6276
      😳wow, really glad I bought a SS inscription plate for £30 and bonded it to my IM now
      • SE_30
        • Apr 2010
        • 1114
        • Home: England Current: Israel
        A few have commented that the RS2 inlet flow tract is not as good as the ABY,zero or even negative performance gains. The 3b is meant to be as good as if not better than all of them for flow.
        Have a search, there are a few threads with some good info covering your question.
        Stuart
        B2 90 quattro with boost
        • andy10v
          • 5996
          RS2 and ABY are larger volume
          Originally posted by Pisobiker
          3B intake manifold's internal volume is ~3.3 liters and RS2 one is ~4.2 liters (both including the 5 inlet ducts).
          And 3B flows more on a static flow bench?
          RS2
          3B
          ..as on a Superflow bench with 28 inches. All within 4% max/min, within 1.1% of average or so, this is untouched right off the CNC. Just for reference 8) I'm getting a 3B flowed right now for comparison 8)
          Sold ABY-stock
          • Quattronaut
            • May 2013
            • 273
            IMHO that flow bench measurements are thrown-out money. Air flow inside the mani is affected by so much factors, and each of them varies from motor to motor, that nobody can say, what the result in real car using is. Change cams- another flow. Change throttlebody- another flow. Change air piping- guess: another flow. RPM band is 7000rpm variable. No flowbench can simulate that.
            From the manis on the pics, I would take the Porsche one- because there is less difference between the cylinders, and IMHO that is more important than that little overall flow numbers. But this also is "trying", not more. Maybe it works little better in some way- but I wouldn´t be surprised if not.
            And overall: Up to 500hp it is just the heck...Every common IM (Wagner, AAN, 3b, ABY, ADU) will do the job good enough.
            • Classix
              • Jan 2010
              • 202
              • Home: Lithuania Current: United Kingdom
              so, if i want to fit on my ABY head rs2 inlet manifold it will fixed like original?
              • Christophski
                • 3632
                Does the 3b inlet manifold bolt on and work on an ABY without any modifications to it, or anything around it or that bolts to it? I have a n ice shiny 3b one sat around that would look great on my ABY.
                • rxl
                  • 1913
                  3b intake manifold will not fit as the piping is different and the manifold has other dimensions
                  • quattrostyle
                    • Oct 2006
                    • 6229
                    Indeed, won't fit around the back of the valve cover.
                    • sailaz
                      • Oct 2009
                      • 647
                      • Country: United Nations
                      but in general all manifolds can be interchanged if piping or something else is not an issue, I mean the fixing points on the head are the same on all 20V heads - RR, NM, 7A, 3B, AAN, ABY, ADU
                        Yes, it fits exactly the same.
                        • rxl
                          • 1913
                          the cam cover is different.
                          • GazzaG60
                            • 4133
                            porsche had to do something to make the rs2 different. think they were running out of ideas as the s2 was such a good starter for 10.
