hi
just ordered the rs2 front and white line rear arbs for my s2 just wondered if they are easy enough to fit and if they make that much differance
cheers keith
hi keith,their quite simple to fit as long as the bolts holding the brackets on dont snap.But apart from that its only 4 bolts and the droplinks,just done it on mine then had it all aligned and it was well worth it!
dean
nothelle n300,alcon brakes,sachs suspension kit,lots still to be done!
thanks guys did have a go the other day started on th drop links and the whole nut just spun so gave upso may get somebody else to do them as i know it will go **** up
You need to hold the drop link with a spanner keith, there's a slotted section on the drop link
Some of the bolts can be a right woofwoofwoofwoofwoofwoofwoof...
I had no problems with the subframe bolts - had issues with the droplinks though. The rears were totally knackered anyway, so I just cut the boot and popped the ball joint out so I could pull the RARB away. Remove the rear wheels and access to fully remove the droplink is much easier! Off with the old, on with the new, and it's much easier putting it back together
As for the front, I didn't do this one personally, but I think it's a little more difficult for access. I replaced the plastic droplinks with RS2 (metal) items anyway - again, off with the wheels and it was alot easier!
ps - might be worth replacing the front ARB droplinks as a matter of course - I didn't when I put the RS2 ARB on the front and sure enough, after just a few weeks, I started getting a clonk from one fo the front droplinks that had given up the ghost - I guess the extra force generated by the stiffer ARB sent it over the edge...
