Engine machining...
  • SteveH
    • 4460
    Bassett Down Balancing use an engineering firm in South Cerney. They are very good, but expensive. I've had work done there and I can't fault them.
    HTH
    91 Modded 3B
    14 A6 Avant Black Edition
    • SteveH
      • 4460
      Oh, and if you need a torque plate for the rebore, Aelred has a fine example. I believe Mark used this during his rebuild.
      91 Modded 3B
      • twoqu
        • Sep 2003
        • 3103
        HTH
        That's because you got a very advantageous price if I recall:mischeif:
        • SteveH
          • 4460
          Who am I to complain if their invoicing system required an update or two
          I believe they have now moved into the 20th century with computerised invoices.
          91 Modded 3B
          • twoqu
            • Sep 2003
            • 3103
            #20
            But seriously! Sad fact of life but you have to pay a little extra sometimes. However it shouldn't be too difficult to find an established engine machine shop relatively locally. Accuracy of dimension and the correct bore finish for the rings are the priority.
            Don't forget that you will need to tell them what the correct bore size will need to be. You might need to research the bore clearances for the JE pistons. Most aftermarket pistons tend to like more clearance than OE pistons.
            Good Luck!
            • quattro
              • Dec 2004
              • 768
              #21
              Originally posted by Jamo
              Lets be honest here mate, I'd wouldn't take a tonka toy to QPS but thats another story.
              I would investigate Bassett's price before you commit.
              Can I ask what the rough price of the rebore was by QRS out of interest please?
              Why not? i thought they were a reputable company? i must be mistaken then! thanx 4 the heads up tho!
              £185+vat was the price. not to bad i think.
              Probably the longet S2 project in history EVER!
              • twoqu
                • Sep 2003
                • 3103
                #22
                Careful here! You are getting confused. There is QST which is Kim Collins and QRSport which is Tim Cooper's outfit.
                Sounds like at £185+vat you are paying for somebody to make the trip to the machine shop. Something you can do yourself!
                • merlin's S4
                  • Jan 2005
                  • 1539
                  Tim Cooper is no longer involved with QRSport! But after my experience, I'm not sure whether that's a good or bad thing!?!
                  • Mark Halligan
                    • 2001
                    Yep, I also made up some spacers so that OEM bolts or ARP studs can be used to secure the plate to the block (plate is no where near the height of a head).
                    I left them with Aelred and the plate.
                    Mark - Modded
                      Does this mean OEM bolts or ARP studs are required prior to boring? Thiking of an issue here with the diesel block different head stud size.
                      • Acidburn
                        • 13459
                        Basset Down Balancing are fantastic - think they are still in Swindon area. They have plenty of I5 experience.
                        Paul
                        This is who Dialynx send all there work to, Kieth happened to mention it whilst I was down there, they have had alot of experience as others have mentioned.
