Looking at an S2
  • Sonic
    • Jul 2006
    • 5514
    #31
    RS6 Alloys
    S2Forum.com Administrator
    • Whitedog
      • Jan 2007
      • 142
      Originally posted by Knight Rider S4
      Looks like it should be a special edition "Cadbury's S2"
      • gordon c
        • 81
        that looks a really tidy S2 get it bought matey
        • madS2
          • Nov 2005
          • 552
          lol very strange looks like the 1 i had for sale,where did you get it mate?
          Looking for an S2 ABY
          • madS2
            • Nov 2005
            • 552
            M582 LYF??280bhp remapped model mate,Full stainless steel backbox from powerflow,Cone filter,drilled disks,wood trim.Very fast and capable S2!!
            • A8_Dan
              • Jul 2007
              • 32
              Yes thats the spec! do you know the car? was it yours?
              Poorly 2.3 10v NG Coup!!!
              • A8_Dan
                • Jul 2007
                • 32
                Can the S2 be plugged into by Vag-com?? May take my laptop along.....
                • 4WheelDrifter
                  • Oct 2004
                  • 5773
                  • Country: Devon
                  #38
                  Indeed you can. The diagnostic plugs are in the main fusebox on an ABY S2. Don't forget your 2x2 connector.
                  SS
                  • A8_Dan
                    • Jul 2007
                    • 32
                    What is a 2x2 connector? I just have the usual obd connector.
                    • 4WheelDrifter
                      • Oct 2004
                      • 5773
                      • Country: Devon
                      #40
                      Ah. Vag-Com won't be much use to you without the 2x2 adapter.
                      SS
                      • A8_Dan
                        • Jul 2007
                        • 32
                        oh i see. Where can i purchase one of them from does anyone know?
                        • vonbeck
                          • 2455
                          ross tec as e-bay ones are very dodgy
                          ABY Cricket Green Pearl Coupe, blk leather
                          THE ONLY TROUBLE WITH DOING NOTHING IS KNOWING WHEN YOUR FINISHED!!!
                          • A8_Dan
                            • Jul 2007
                            • 32
                            Well i drove the car yesterday!
                            Initially battery was flat but that didnt bother me as it showed me that the engine was cold and not started for a short while. Put a batt pack on, turn the key and it quickly started! I was so suprised as how quite the engine was considering! My V8 is noisy for a sec or two until the oil is pumped if stood for a week!
                            Few gentle taps on the revs, no smoke of any kind! exhaust sounds good too!
                            Sunroof is jammed? The motor tries to open it but can't. Not a major problem i dont think but stand to be corrected.
                            Let it warm up a bit before driving away. Brakes felt good after the rust was removed. The steering sometimes made a groan like it needs greasing somewhere (my S4 did the same thing!)
                            Then came the boost testing! initially after releasing the clutch, the car was slow until about 3k revs then woosh! it took off! again through the gears its slow then turbo kicks in. With it having a cone filter you can hear the recirc valve dumping the air back into the system. But also, when driving hard you can hear a slight whistle, again coming from air cone direction. Is that normal hearing this due to the cone? or is it the dreaded turbo whistle? I know you will get some kind of noise.
                            Braking from speed seemed a bit wobbly! maybe a ball joint worn but should be picked up on mot if anything wrong.
                            Have got a video clip of speedo but trying to convert and reduce the size so i can post it. Maybe you can judge from 0-60 if it seems about right? I didn't time it though. The car is possbily mapped to 280bhp! http://uk.youtube.com/watch?v=Q4o_WA8QqbM Looking at the video, about 7secs 0-60
                            (sorry about the side view!)
                            He looked at my A8 and would do a straight swap!
                            Dan
