Boost Gauge Pic & Dash Upgrade(Not Finished) Pic..
  • Acidburn
    • 13459
    Cool, do you know if they ever put them into production and was the sensors easy to wire in/mount?
    • LHD_Kid
      • May 2006
      • 3697
      #32
      Bo, you are in serious need of a carbon trim set....!!!!!!!!
      everyting else looks sweet....
      Chris
        Its a kind of rolling gauge shop
        • neebover
          • May 2005
          • 359
          Originally posted by s2_bo
          The alternators charge circuit runs through that bulb, if you have an LED in there for some reason it doesnt charge properly. Infact it almost doest charge at all, at least mine didnt.
          I found this out the hard way.
          Ended up replacing battery, voltage regulator etc. when all it needed was removing the LED and replacing it with a normal 12v bulb.
          As soon as i did that the voltage staid steady and it charged again.
          Someone on the forum pointed this out to me.
          So if your converting to LEDs dont change the Battery one.
          Bo, without knowing the above prior to this post, I changed my battery led to blue a good few months ago, There has been no problems since.
          Chris.
          Missing her lots!
