Got myself a new beast. I got i cheap as the gearbox is broken. I'm planning on fixing it my self as a winter project. Really happy with it Of course i will update this thread when i have more photo's
Rs6 C5 :)
rs6
Great car , ive had mine just over a year now, amazing bit of kit,,Attached Files
Thanks all
Originally posted by quattrostyle View PostStunning example, great colour in and outside.
Not too sure on the tailpipes though..
Originally posted by chris View PostGreat car , ive had mine just over a year now, amazing bit of kit,,
Originally posted by gmac78 View PostGood choice, had one for about two years now and certainly puts a smile on your face. If it's not mapped already be sure and get both ECU and TCU done. Much improved driving experience after getting the TCU done.1360kg/600Whp Avant 0-200km/h 9sec
Getting the TCU done removes the torque limiter in the gearbox, gives you more control over the gears when in tiptronic mode, activates the lock up clutch earlier resulting in a more "manual" feel to the box. See if you can hold 30mph in 5th gear? If yes your box will be mapped, if not the box will hunt up and down between 3rd and 4th which is most annoying. Line pressure within the box may also be increased resulting in a quicker, more positve gear change.
Originally posted by RichLV View PostIt's so gorgeous... I'm wanting one myself, too bad they only came with autos though...
http://audis4parts.com/audi-a6-tip-t...sion-swap-kit/
It lists all the bits you need if you want to source it yourself.
Originally posted by gmac78 View PostGetting the TCU done removes the torque limiter in the gearbox, gives you more control over the gears when in tiptronic mode, activates the lock up clutch earlier resulting in a more "manual" feel to the box. See if you can hold 30mph in 5th gear? If yes your box will be mapped, if not the box will hunt up and down between 3rd and 4th which is most annoying. Line pressure within the box may also be increased resulting in a quicker, more positve gear change.
Started on the removal of the front. On Sunday i will start on removing the engine and gearbox.1360kg/600Whp Avant 0-200km/h 9sec
Best to remove DRC if it's playing up, aftermarket shocks can be bought quite reasonable, i paid £550 for Koni adjustables. Normal A6 suspension arms etc can be fitted so can also be bought at reasonable prices. I see your intercoolers are leaking, whip them off, give them a good degrease and pressure test in water to determine where the leaks are coming from. JB weld them and job done, nice air tight intercoolers for not much monies.
