Modified URS6 running rich
  • twoqu
    • Sep 2003
    • 3103
    Would have thought that £300 would get a set of injectors and ecu.
    But it could be something as simple as a fuel pressure issue rather than an expensive sensor problem. So its prudent to try and eliminte basic mechanical issues first.
    Obviously the decision is yours to make. Depending on the modification of your ecu the expense in converting to PRJ's setup could be a bit of solder and a wire! The eproms need to be reprogrammed but that might only cost the price of a stamp with a bit of help from the Forum! You would still need to find a set of stock injectors though.
    The car will not obviously have 400bhp but it should drive off boost sufficiently to pass the MOT. The ecu would be reversable as all you need to do is save the original file on the chips. This would only be the case if the ecu already had the correct map sensor installed. If not its going to be a extra few quid. So if you or a friend is handy with a soldering iron it could be a relatively affordable option just for the MOT. You will have to exercise restraint as the basic mod is for effectively a stock vehicle.
    You would need to open the ecu up to inspect the map sensor and remove the eproms. There are guides to help.
    It seems a retrograde step but its cost effective and reversable.
    • prj
      • Mar 2010
      • 6308
      Pretty sure messing with the ECU is outside of most people's abilities, unless they happen to work in electronics.
      It needs pressure test first and foremost.
      Nothing I can do to help from this end really due to distance.
      Standalone ECU + mapping is going to run you at least 2k or so.
      • twoqu
        • Sep 2003
        • 3103
        [QUOTE=prj;n2029538]Pretty sure messing with the ECU is outside of most people's abilities, unless they happen to work in electronics.
        You were right that the MAF would be the death of these vehicles eventually!
        Shame the Hotfilm MAF project was not persued. Most people would have been up to swapping MAF's !
        • S4Marc
          • Mar 2017
          • 108
          It's certainly outside of my capabilities, I'd do more harm than good
          • S4Marc
            • Mar 2017
            • 108
            [QUOTE=twoqu;n2029542]
            It's a shame that the MAf's have increased in price sooo much, I did place a wanted ad in the classifieds but nothing came of it
            • S4Marc
              • Mar 2017
              • 108
              I'm going to place an advert in the classifieds and hope somebody else can save her, really don't want her broken for the engine
              • S4Marc
                • Mar 2017
                • 108
                I'm hoping this has something to do with it
                I've tested the MAF using a G70 flow chart from quattro world and it appears fine
                This gallery has 1 photos.
                • prj
                  • Mar 2010
                  • 6308
                  Well yeah it needs a pressure test first and foremost.
                    S4 Marc
                    Where are you?
                    • S4Marc
                      • Mar 2017
                      • 108
                      Originally posted by newsh
                      S4 Marc
                      Where are you?
                      Down on the south coast in Dorset
                        Ok, I’m up in Surrey, I’ve got the bungs to do a pressure test if you want to borrow them
                        • S4Marc
                          • Mar 2017
                          • 108
                          That would be amazing, happy to pay a deposit and postage
                            PM me an address to send to
                            • S4Marc
                              • Mar 2017
                              • 108
                              Took her for an MOT today in the hope that the boost leak would cure the rich running..........alas no joy. I'm not sure it's ever passed a UK MOT after being mapped
                              CO was 7.2% and in the UK it needs to be 0.3%
                              The tester feels too much fuel is being injected and stated the catalytic converter seems fine
                              • S4Marc
                                • Mar 2017
                                • 108
                                Is getting the car remapped the next port of call or a £350 MAF sensor?
                                It runs well and pulls hard with no obvious black/brown exhaust smoke
