AAN with Wagner EM
  • igor136
    • Jun 2014
    • 363
    • Country: Croatia
    AAN with Wagner EM
    Good evening guys. Please help. I have a crack in the exhaust manifold. The car is UrS6. The turbine is original. I wonder how the car behaves with a Wagner rs2 exhaust manifold? I read somewhere that the turbine fills a little less (0.1 bar) than with the original exhaust manifold. Is that true?
    Are you satisfied with Wagner EM?
    Poslano sa mog SM-A135F koristeći Tapatalk
    1-2-4-5-3
  • robo
    • Aug 2004
    • 2086
    • Home: Poland Current: England
    Highly recommended.
    sigpic_________
    Rob
    • K Simmonds
      • Dec 2007
      • 7633
      If your still on a stock AAN manifold then a Wagner RS2 EM will be a huge upgrade, it will decrease spool up time ever so slightly... Not reduce turbine pressure, I don't know where you read that but it's wrong.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • igor136
        • Jun 2014
        • 363
        • Country: Croatia
        On a German forum. The explanation was that the Wagner has a larger pipe diameter, which reduces the velocity of the gases. Wagner exhaust manifold is around 650 euros. Until half a year ago, original exhaust manifolds were available for purchase at Audi Tradition. I think the price was 850 euros. I installed an original used exhaust manifold without cracks on my car. Before 70tkm. Now I have one external and several internal ones. Very poor quality.
        1-2-4-5-3
          • Dec 2017
          • 6006
          Very happy with my Wagner. Be careful as cheap copies out there. Got mine in group buy from LS Cartek.
          I see what they mean about spool up but it's not something you will be able to notice.
          • K Simmonds
            • Dec 2007
            • 7633
            The Wagner EM does indeed have larger diameter runners, but the the exhaust turbine acts as a restriction and backs up the exhaust gases in the manifold slightly so anything you can do to increase the flow of gas either side of the turbine will increase performance. Obviously unless you get the car remapped you won't see any real gain in power but fitting either a stock RS2 or Wagner manifold can only help the car run better as both flow way better than any of the stock 20VT manifolds.
            The 3B EM is particularly poo but the the ABY and AAN ones aren't a great deal better, all are very prone to cracking due to the design with two extra runners going to the waste gate port causing big differences in temperature in the casting which cast iron doesn't like. The RS2 and Wagner version are a much better design, they still crack though, well stock RS2 ones do around the collector for the turbo but they don't tend to leak. I can't really comment on the Wagner version as I don't run one but I can say I've never heard of anyone complaining of them cracking.
            1994 MTM RS2.
            2000 B5 TQS.
            • pfi
              • Jun 2016
              • 274
              • Country: Norway
              I'm having a RS2 copy on my 3B, not remapped, mby it's only imagination but it "feels" better than the std EM ...
                It will spool quicker.
                • igor136
                  • Jun 2014
                  • 363
                  • Country: Croatia
                  The problem with standard exhaust manifolds is that they leak everywhere. A little through the cracks a little through the seal. Because they are distorted. When I installed a crack-free exhaust manifold a few years ago, the turbine was charging from 2000 rpm.
                  1-2-4-5-3
                  • K Simmonds
                    • Dec 2007
                    • 7633
                    The RS2 design manifolds not only flow considerably better, they're also much less prone to cracking as they do away with the silly wastegate runners which helps the whole casting both heat up and cool down more evenly, which it has to do 1000's of time's in a lifetime.
                    Genuine RS2 manifolds (or decent copy's) do tend to develop hairline cracks around the collector for the turbo but rarely leak, Wagner stuff is well designed and produced and I've not heard of them cracking as I mention above.
                    It's probably the best mechanical upgrade one can do to the engine and exhaust system.
                    When I first got my 3B it had a Nothelle modified EM which are even more prone to cracking than stock as they use some weird grade of SS welded into the original cast iron, when I fitted a genuine RS2 manifold it spooled up about 2/300 RPM earlier using the small K26 hybrid Nothelle use with their N300 conversions.
                    Then I fitted a K24 7200 and all the other RS2 parts and well mapped ECU and all hell broke loose!
                    1994 MTM RS2.
                    2000 B5 TQS.
                    • igor136
                      • Jun 2014
                      • 363
                      • Country: Croatia
                      I meant bent S2 exhaust manifold. You can watch the video at 3:00 min. I have the same situation.
                      1-2-4-5-3
                      • K Simmonds
                        • Dec 2007
                        • 7633
                        Ah, I see what you mean, your talking about the manifold warping, pity the video doesn't have English subtitles as I don't speak much German.
                        The mating surface of the manifold has to skimmed to fix this issue.
                        1994 MTM RS2.
                        2000 B5 TQS.
