1. It gives you enough info to be worth checking.
3. Sounds like you have power then, you can try a different switch, but I think it'll be the motor.
5. To unlock, turn to the right and hold it there, then push the button in, hopefully it'll open. The central locking would only lock my boot due to the boot wiring loom issue and it felt like I was fighting the lock to get it to the unlock position with the key. Once the looms were repaired, there was very little resistance
6. I missed the obvious here, but if the oil pressure is going off the scale with the engine off then you need a new sender, which it sounds like you do. Having driven a few of these Audi, the oil temp gauge moves less than you'd expect until the engine is under sustained load. Mine moves off the stop when driving around town, but not a lot more. If it's never moving at all then it sounds like you need to investigate.
Turning into a bit of a money pit!
