@s2driveruk - Mine has add the chain rattle on cold start for more than the 2yrs I have owned it - its the only time it makes noise as the tensioners build up oil pressure - its certainly not a nice sound but its gone in a second. I do plan to do the full chain service someday but the parts (and bravery) required for a DIY job are not trivial at all. I bought mine for little money (~5k) and it was heavily loaded with options (except for RNS-E which I added myself) so I was happy enough with the chain rattle on startup. Mine does consume more oil than it should - this is a pretty common trait of the B6/B7 - its a combination of valve cover gaskets and crank ventilation.
@mcmandmar - the wiring on the B6/B7 is definitely a lot more complex than a B2/B3/B4 but its actually a lot better organised once you get your head around it.
Worst thing about them is the sheer lack of space to do almost anything in the engine room beyond an oil & filter service - you need lots of patience for some of the fiddlier jobs.
They aren't famous for MPG efficiency either - I get 23-25 on average but mine isn't doing many long journeys.
They are famous for being hard to tune / upgrade - its maybe more correct to say that its just very expensive to get 30-50 more bhp out of them compared to chipping an S2. There is a supercharger kit from the US for mad money which takes you into RS4 territory, but ignoring that you are looking at very expensive exhausts & headers along with a remap from a decent source to get you into 370-390bhp country (depending on whose hype you believe).
Ideally, you want to hold out for a B7 model (better range of options & media upgrades available if you find a car lacking in such gadgets) that has already had the chain service done and maybe a remap and/or zorst upgrade.
Alternatively - spend more money and get a B8 3.0 supercharged V6 S4 - with a pulley swap and remap those things absolutely fly - but they don't look as good to me !
