Tell me about the S4/S4 avant
    @s2driveruk - Mine has add the chain rattle on cold start for more than the 2yrs I have owned it - its the only time it makes noise as the tensioners build up oil pressure - its certainly not a nice sound but its gone in a second. I do plan to do the full chain service someday but the parts (and bravery) required for a DIY job are not trivial at all. I bought mine for little money (~5k) and it was heavily loaded with options (except for RNS-E which I added myself) so I was happy enough with the chain rattle on startup. Mine does consume more oil than it should - this is a pretty common trait of the B6/B7 - its a combination of valve cover gaskets and crank ventilation.
    @mcmandmar - the wiring on the B6/B7 is definitely a lot more complex than a B2/B3/B4 but its actually a lot better organised once you get your head around it.
    Worst thing about them is the sheer lack of space to do almost anything in the engine room beyond an oil & filter service - you need lots of patience for some of the fiddlier jobs.
    They aren't famous for MPG efficiency either - I get 23-25 on average but mine isn't doing many long journeys.
    They are famous for being hard to tune / upgrade - its maybe more correct to say that its just very expensive to get 30-50 more bhp out of them compared to chipping an S2. There is a supercharger kit from the US for mad money which takes you into RS4 territory, but ignoring that you are looking at very expensive exhausts & headers along with a remap from a decent source to get you into 370-390bhp country (depending on whose hype you believe).
    Ideally, you want to hold out for a B7 model (better range of options & media upgrades available if you find a car lacking in such gadgets) that has already had the chain service done and maybe a remap and/or zorst upgrade.
    Alternatively - spend more money and get a B8 3.0 supercharged V6 S4 - with a pulley swap and remap those things absolutely fly - but they don't look as good to me !
      It's all been said already really. The timing chain issues have been overstated in my opinion, although still a risk of course. The rattle is often caused by a leaking check valve that lets the oil drain back out of the heads. Definitely get one that's been on a proper service interval not the stupid Longlife idiocy. They have no real character but are a great all-round car, good at everything, comfortable and reliable, most of all they are now cheap as chips
      What I have had to do on ours in around 5 years:
      Regular service - around £100 including oil (9 litres)
      Rear wiper motor - these fail as the wash fluid is pumped through the spindle and they corrode
      Front wiper linkage - these aren't properly sealed so they start to seize up after around 5-6 years
      Boot solenoid - these start to fail in hot weather meaning you can't open the tailgate
      Front suspension arms - expensive and lots of them. The upper control arms are an absolute bitch of a job to change the originals as the pinch bolt seizes in the upright
      Alternator belt - not on the service schedule so expect it to give up after around 60k
      Oil level warning sensor - these go bad and give false warnings
      Cam cover gaskets - these don't seal properly, actually I think the cam covers warp
      Coil packs - well documented failures, should have been fixed for free on the dealer programme
      Discs & pads - cheap
      Wheels bearings - easier than the S2 as the bearing is a bolt-in cartridge not a press-in unit.
      Downpipes - bitch of a job. Ours needed changing as the pre-cats disintegrated after multiple simultaneous coil failures. Got a pair cheap second hand.
        @Error - are you talking about front or rear wheel bearings ?
        I have one starting to go - been droney for a while but not getting worse and it doesn't change around corners so must be a rear... I am a bit loathe to do it as the wheel alignment on mine is perfect and I'd hate to upset that along the way (or pay loads for Audi to do it on the official rig).
        Jobs on mine in 2yrs beyond oil services are -
        - RS4 sporty pedal upgrade
        - Aero wipers front & rear (hard to believe a 2003 car left the factory with jurassic wipers)
        - Moved jammed zorst flaps from closed to open position - the vacuum actuators get sticky... was superseded by electrically controlled flap on B7
        - Right Aux Rad deleted (it was leaking)... making way for better air intake as well someday
        - HVAC control unit upgrade to B7 (mine had really crappy looking buttons peeling)
        - RNS E upgrade (from RNS-D)
        - Adjusted tailgate to seal/close better
        - Glovebox upgrade to OE Coolbox
        - New spark plugs
        - New battery
        - F36 replaced (clutch pedal position switch)
        - New cam covers & gaskets yet to be fitted
        - B7 RS4 RARB still to be fitted
        - Street density engine mounts to be fitted (with electro-hydraulic ECU nonsense deleted)
          I've done both rear bearings, they are the same type as the front (might even be the same part?)
            #20
            Originally posted by nicksonmsport
            this chap bought the car for 10k on finance, 18 months later the chains failed, the car had depreciated to around £6k, he then spent another 5k to fix it, and then sold it for 6k. lost 11k on it in 18months including interest on loan.
            I feel sick just reading this, glad I 'just' have an old UrS6.
            Starting to think of it as very straightforward and reliable, as well as less expensive to buy.
              #21
              Bang for buck - the 20VT S2 & UrS4/S6 are pretty hard to beat !
              • Ian_C
                • Oct 2007
                • 1011
                I absolutely loved mine. Paid a teeny bit more for a really good one with the right spec and history, completely reliable over the four and a quarter years I ran it
                B5 B6 B7 B9
                • s2driveruk
                  • 12696
                  i love that....i'd have one in that colour if I was to go down this route.
                  1992 3b S2 Coupe
                  • Cordoba16vt
                    • Apr 2014
                    • 182
                    • Country: Bulgaria
                    #24
                    That is why I keep on buying older and older cars - my last purchase is a 1985 B2 90Q, to keep company to my RS2'd 1995 C4 S6
                    • hunker7
                      • Mar 2014
                      • 3487
                      #25
                      Ita so easy to work on them too, if you have a spanner set you can pretty much do the lot. and you can ALWAYS improve them.
                      '93 Audi UrS4 Avant
                      '15 Audi A7 quattro 3.0 TDI
