Hi there, I'd like more details on the Audi Coupe Tdi that were sold in the EU. I know they came with the 1z motor (which were later found in Vw Passat's here in 1996) and were only FWD.
I'd like to go diesel in one of my Coupe, but is a quattro and I want to keep that - Canadian winters !!
So, here's a few questions to start with but also looking for been there, done that experience :
1) Is the subframe and motor mount for 1z TDi's different than the 7a Quattro's ? If yes, can a subframe of one or the othe be adapted to support the swap ?
2) What transmission does the 1z use ? Can I keep my 01a and change the gearing inside ? If yes, what clutch do i need to use ?
Bottom line, I'd like to keep this as simple as possible and the less cost as possible.
Most parts needed for easier TDi swap would come from Europe and I'd like to keep that to a minimum as I would want this one to become my daily driver and be easily maintained. We got a LOT less TDi models here and are limited in the engine/car combination that were imported here.
