Coupe Rear Tie Rod bushes
  • Acidburn
    • 13459
    Alex - might be worth starting it up as a proper group buy if thats what its going to end up as, probably get more interest then
      Didn't want to start a GB until i had an idea of prices really, thats the first question that gets asked lol.
      At this rate i might speak to Volcano RS about the guy he uses for his nylon bushes and see if we can get a run of 10 set or something..... no way tis going to be cost effective to look at poly at this rate
      • goodall
        • Jul 2008
        • 810
        count me in
        would been on top the list if wasnt busy all yesterday only noticed this now
        id be for poly but make no real difference car aint a commuter
        what is the plan with the mk2 joint? use stock bush holder and adjuster and length of rod thread either end?
        though may bend if that the proposed idea as a piece rod that length very little resistance to bending as it cant 'spring', note why audi made it curved to increase resistance to curbs
        • stiglet
          • Aug 2007
          • 1264
          We reckon the mk2 Golf item "might" fit. The hole is the right size we just don't know if the taper is the same. And yes, we plan to use a straight rod with either a heim joint on the other side or one of these bushes.
            the inner rod ends are actually a really good design as stock - would last loads longer than a heim joint and with a proper bush in them and an appropriate threaded bar and a cheap and easily replaceable outer rod end would be the perfect solution for the rear tie rods for road and track IMHO.
            • k.alle
              • Feb 2008
              • 801
              Count me in for a set!
              hoping this will come through..
              nylon sounds fine, or poly.
              Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
              http://www.garaget.org/?car=52877
                ok matey
                So far we have:
                Error 404
                Madwolf_uk
                Acidburn
                Andy_casey?
                S2central
                Spink?
                Anton
                Goodall
                Terrybullwon
                k.alle
                • quattro
                  • Dec 2004
                  • 768
                  #23
                  Why not just use 2 rose joints with different threads, a thick sided Alu tube with the nuts welded to the end and a locking nut each side.
                  More effective and less complicated.
                  Probably the longet S2 project in history EVER!
                  • anton
                    • Jan 2005
                    • 802
                    the problem is i think most people would prefer to keep the taper on the hub, incase they ever go back to standard..the 034 tapered insert jobbies for rose joints cost a fair bit, as do the rose joints themselves compared to normal ball joints. i do agree that the rose joint solution is the best choice for some tho, if this falls through for any reason thats what i'll probablly end up doing.
                    Ant
                    91' Coupe quattro 20v - project
                    KW V2s and other goodies
                    now gone
                    03' BMW 330CI - Sold
                    08' A5 Coupe 3.0l tdi quattro - Sold
                    57' BMW 525d M Sport Touring
                      for almost everyone thess bushes would be an upgrade for the stock set-up, and easily DIY fitted.
                      Rose joints are all well and good but they're not cheap and don't last long unless they are properly sealed - and for most poeple those are the two prerequisites to fitting parts to their car
                        I've got some dims for these bushes now so will put together a semi-technical drawing tomorrow and see what these manufacturers say.
                        Should be an easy one as long as theres enogh interest to make it worthwhile / cost effective
                          Right, i've knocked together a basic roughly scale drawing of the rod and and possible bush design on MS Publisher
                          comments / ideas / abuse welcome
                          hopefully this is enough for these mfrs to let me know a pallpark cost and possible order numbers etc
                          I'm going abroad for 2 week tomorrow so will hopefully pick this up on my return and move things forward.
                          cheers
                          Alex
                          EDIT: Can anyone confirm if this bush would potenmtially work for the Type85 or URQ?
                          • mikeraz1
                            • Jun 2008
                            • 342
                            • Home: Scotland Current: United Kingdom
                            #28
                            I'll have a set
                              Error 404
                              Madwolf_uk
                              Acidburn
                              Andy_casey?
                              S2central
                              Spink?
                              Anton
                              Goodall
                              Terrybullwon
                              k.alle
                              mikeraz1
                              • Acidburn
                                • 13459
                                Any progress with these mate?
