Uprated 3B clutches
  • SteveH
    • 4460
    Here's a pic of one of the pressure plate straps - The pressure plate has three of these. This is a Sachs pressure plate, and as you can see it has a fairly long strap constructed from two strips of spring steel. The uprated pressure plates have shorter straps and they are constructed with up to four strips of spring steel. These spring steel straps can also be kinked prior to assembly, to aid clutch bite and help prevent premature failure of the straps.
    The LuK (OEM) pressure plate is a better design as it uses shorter straps, however, the straps are weaker than those used on the Sachs unit.
    Both can be modifed to take extra and shorter straps.
    The weakest link for high output motors is the friction material. This is also the case if you're into red light racing with high rev starts. The quattro system produces such good traction that something has to spin, in most cases it's going to be the clutch and not the wheels
    91 Modded 3B
    14 A6 Avant Black Edition
    • audiman
      • 4827
      Thanks for that one steve, i dont have any pics of clutches here.
      Tom C - www.rcmr.co.uk
      Audi UR Quattro
      Audi 100 C3 2.0 5 cyl 115ps
      Audi B5 RS4 645ps 911nm
        Id rather it be the clutch than go and damage the gearbox or driveshafts etc though.
        • audiman
          • 4827
          Ah yeah but when you drive the car even at high speed, when the torque comes in it just slips. Thats even without 'slipping' it to pull away
          Audi UR Quattro
          • diesel des
            • 3896
            #20
            I will need a strong clutch for my 20v URQ project that will use a aby, with a 3b flywheel and a 016 box. Does the 016 box require a different number of splines than the box you guys use? EG is clutch the same? Thanks,des.
            • s2-1.5bar
              • Sep 2004
              • 193
              • Home: Lithuania Current: United Kingdom
              #21
              Hi
              I got 3B(from 200tq) mounted to 016 box. The clutch and flywheel came from 3b.
              • diesel des
                • 3896
                #22
                Originally posted by s2-1.5bar
                Hi
                Ok then the same clutch will fit my car too. Im interested too then. Thanks,des
                • audiman
                  • 4827
                  Im still waiting a reply
                  Audi UR Quattro
                  • Sweeper
                    • 1317
                    • Country: Latvia
                    #24
                    Tom: what is the clutchnet clutch part number for 3B ?
                    Vadim.
                    New engine (mechanical PKM head) , Alcon 332mm brakes , Pauter rods , Mahle pistons, GT30R , kw v2 sucpension , new exhaust. 608HP. For SALE !
                    • audiman
                      • 4827
                      Not sure Vadim, I will phone them from work tomorrow night
                      Audi UR Quattro
                      • Mark Halligan
                        • 2001
                        Tom,
                        please include me in this as my clutch has started slipping too, albeit intermittemtly.
                        thanks,
                        Mark.
                        Mark - Modded
                        • audiman
                          • 4827
                          I have tried to phone them but got an answering machine!! I did leave a message, but i have had no reply. I will try again in the week. Im gonna have to sort this fairly soon, as my clutch isnt exactly loving the power now!!
                          Audi UR Quattro
                          • s2driveruk
                            • 12696
                            Tom, any news on this yet (costings etc etc) as mine is starting to slip...
                            Cheers,
                            David
                            1992 3b S2 Coupe
                            • SteveH
                              • 4460
                              Clutchnet are useless at answering e-mails. They have asked for a clutch to be sent to them before they will quote on price, etc. I have a spare (new) 3B clutch that will be sent to them in the New Year. Hopefully, it wont take too long for them to advise what's available. Lets hope the Dollar stays as it is for a little longer.
                              91 Modded 3B
                              • sla_s2
                                • 166
                                #30
                                i got clutch from cluthnet without such bul...ting!
                                sla s2
                                sla
                                '91 s2 3b, 305hp, 480 nm.
                                www.4plius.com
