Since I have had a few requests on how to fit the Bosch Fuel pump I thought I would start a thread.
Others can add to it on how they did it or anything I forgot.
First of you need to remove the fuel pump. On a coupe, you need to pull up the carpet in the boot - some of it is stuck down - just yank it up!
You will have to rotate the metal clip to unlock the pump cover - I think I had to knock it with a screw driver and hammer to release it.
Remove the multi plug on top and lift the level gauge out and you can disconnect the internal connector.
