Bosch Motorsport 044 Fuel Pump Coupe Fitting Guide
This is a sticky topic.
My 044 has some kinda high pitch noise, but it has been like that from day one.Comment
I have some mounted external from my tank, Needless to say they are on a switched system!!!ChefComment
Hello friends, where can I find all the information for mount a 044 fuel pump on a RS2? Thanks a lot!
AlessioMy life and my loves
Audi-Porsche Avant RS2
Audi S6 C4 ABT Avant
Audi S2 Coupe ABY
Audi S2 Avant
Audi Cabriolet 2.0EComment
hello guys,so i have also this f...g problem with my pump!all parts are brand new original and this pump comming louder and louder every day,aspecialy when driving on the highway!soon i will measure the fuel pressure when its coming louder and i think its will fail!sure!Comment
yes greg s ,i check all fuel sysytem step by step,all parts are oem and brand new!and the pump is fu...ng noisy!!!!!!for first hour its oki,and then star this terrible noise,especialy when i drove on the hghway!i think that the original fuel regulator is not capable to operate with masiv fuel flow!any ideas how to resolve this problem!
thanks and best rgds!Comment
rs2 pump fitting
i have just finished fitting bosch 0580 254 040 pump which is the same as spec as 044
part numbers for 60mm reservoir 895201779h and strainer 895201531a.
my fuel pump is very quiet at the moment but i am still trying to find a banjo bolt for pump to fit original banjo pipework in tankComment
I am trying to fit a 044 into my coupe, however it is a 94 2.6e originally anyway and not an S2. The problem I am having is that I can't find any cover on top of the tank, can someone tell me how I access the fuel pump on this tank?
Thanks.Comment
Sounds like you need to take off the tank cover (the ridged cover under the boot floor carpet) . First remove the boot floor carpet.
Then peel the carpet flap that is glued across the rear of the tank cover and you will see several bolts. Undo and remove the cover. Done.Panthero Coupé quattro 20vt
Imola B6 S4 AvantComment
