Bosch Motorsport 044 Fuel Pump Coupe Fitting Guide
This is a sticky topic.
  • Billman
    • 4129
    #61
    Originally posted by Billman
    i have a question about the 044 pumps. since yesterday i noticed a gargling noise coming from the fueltank and i think the fuel pump is about to die. is this common on the 044s? i notice no difference cuts or whatever only the noise.
    thanks
    Noone has these kind of noises with his pump?
    Go Holset or Go RS4
    • Jonas_R
      • 3781
      • Country: Denmark
      #62
      My 044 has some kinda high pitch noise, but it has been like that from day one.
      Sleeper S2 Avant +450
      A6 Avant 2.7t Stage 3
      Audi S2 Coupe RS2'ed
      • Billman
        • 4129
        #63
        i had this also but now it changed to something else.....burble gurgle ....
        Go Holset or Go RS4
        • s2_bo
          • Oct 2005
          • 6067
          #64
          I have the same, its very very loud especially if you have the rear seats down.
          91 S2 coupé - RIP
          98 S8 - Luxury barge
          • coolhand
            • Apr 2005
            • 163
            • Home: England Current: Australia
            #65
            Same here from new, and actually glad to know I'm not the only one (!).. although I've also noticed on extremely hot days it does begin to sound a little unnerving in tone, like it's struggling a bit :-O
            • terrybullwon
              • Mar 2006
              • 8782
              I have some mounted external from my tank, Needless to say they are on a switched system!!!
              Chef
              • Bram
                • Aug 2006
                • 2582
                I don't hear my 044 in the Avant. But that is because my 3" exhaust is boomy
                • A80Avant
                  • 10873
                  • Country: Greece
                  #68
                  when hot it does sound a bit louder in mine as well. Maybe it would be a good idea to have a fuel tank radiator!! hehe
                  • Audi-Porsche Avant RS2
                    • Sep 2008
                    • 1041
                    • Country: Italy
                    #69
                    Hello friends, where can I find all the information for mount a 044 fuel pump on a RS2? Thanks a lot!
                    Alessio
                    My life and my loves
                    Audi S6 C4 ABT Avant
                    Audi S2 Coupe ABY
                    Audi S2 Avant
                    Audi Cabriolet 2.0E
                    • ADP
                      • Mar 2011
                      • 200
                      • Home: Bulgaria
                      #70
                      hello guys,so i have also this f...g problem with my pump!all parts are brand new original and this pump comming louder and louder every day,aspecialy when driving on the highway!soon i will measure the fuel pressure when its coming louder and i think its will fail!sure!
                        Its worth checking the pump hasnt slid out of the basket and is touching the outside of the tank
                        • ADP
                          • Mar 2011
                          • 200
                          • Home: Bulgaria
                          #72
                          yes greg s ,i check all fuel sysytem step by step,all parts are oem and brand new!and the pump is fu...ng noisy!!!!!!for first hour its oki,and then star this terrible noise,especialy when i drove on the hghway!i think that the original fuel regulator is not capable to operate with masiv fuel flow!any ideas how to resolve this problem!
                          thanks and best rgds!
                          • dobbin
                            • Jan 2011
                            • 164
                            rs2 pump fitting
                            i have just finished fitting bosch 0580 254 040 pump which is the same as spec as 044
                            part numbers for 60mm reservoir 895201779h and strainer 895201531a.
                            my fuel pump is very quiet at the moment but i am still trying to find a banjo bolt for pump to fit original banjo pipework in tank
                            • MikeyB571
                              • Jan 2011
                              • 57
                              I am trying to fit a 044 into my coupe, however it is a 94 2.6e originally anyway and not an S2. The problem I am having is that I can't find any cover on top of the tank, can someone tell me how I access the fuel pump on this tank?
                              Thanks.
                                Sounds like you need to take off the tank cover (the ridged cover under the boot floor carpet) . First remove the boot floor carpet.
                                Then peel the carpet flap that is glued across the rear of the tank cover and you will see several bolts. Undo and remove the cover. Done.
