1991 CQ Taillight Circuit Board Rehab
  • cgharibo
    • Aug 2011
    • 165
    Hi there,
    I have a few intermittent bulbs within my taillights due to what appears to be the circuit board. When I try to troubleshoot this, a little wiggle bring the bulbs right back to life.
    I tried cleaning the contacts, changing the bulbs, improving the contact pressure, cleaning the connector etc without much progress.
    Any advice on how to improve the taillight bulb connectivity? Is there a contact cleaner/conductivity enhancer that I can just spray on?
    Thank you!
  • Jaswan
    • Apr 2011
    • 765
    Hi
    You could maybe try a conductive paint and paint it on the traces of the board?
    Regards
    Jase.
      I have a theory it's the rivets that connect some of the tracks to each other, some way of tightening the rivets or replacing them with screws might help. I don't think soldering is a solution because the tracks appear to be galvanised. I believe there's a 1/4” spade tag on the side of the cluster that can be used as a direct ground, taking this direct to a chassis point might help and will certainly improve brightness and cure the xmas tree effect.
      • Fat Audi 80
        • 10547
        I have exactly the same problem which causes a "bulb out" X on the dash when the side lights are turned on. I am convinced is the primitive circuit boards + corrosion that is causing the issue. I am trying to work out how to remove the corrosion and return them back to normal operation...
        Any help or advice welcome!
        The Perfectionist
        • Fat Audi 80
          • 10547
          Or....
          The Perfectionist
