How to replace ignition cylinder / barrel FAQ
This is a sticky topic.
  • Eriksson
    • Jul 2004
    • 329
    i thought i share some info and pictures.
    Might be using some strange words so just ask if thers anythingm you dont understand.
    First of all remove the following things.
    plastic cover underneth the steeringwheel.
    ignition connection.
    Instrument cluster (Speedo)
    Steeringwheel
    Steeringwheel plastic covers, both top and bottom.
    Light switches, turnsignal etc.
    And a black plastic cover see picture below, i had to use som force to remove it.
    Black plastic thingie
    Some parts removed
    Loosen the steering rack bolts to make room for wiggeling the whole cylinder out.
    Remove bolt to loosen cylinder (including steering lock)
    all out all parts loosened.
    Drill a hole for cylinder removal make sure to hit the locking notch, approx 3 mm
    Tap out locking pins.
    Audi S2 Coupe - 92
    Koni + H&R. PowerFlex bushes. 3" Exhaust
    RS2 IC. RS2 TURBO. RS2 EX MAINFOLD
    Best ET 2006 13.8 @ 157 Km/h (Stock turbo and EX mainfold)
    Best ET 2007 12.78 402m, 0-62mph: 4.2 sec, Speed: 175 km/h (GTEC)(1.1bar)
    Best ET 2007 201m 8.15@140km/h
    Best ET 2008 402m 12.34@177km/h
    My Project
    http://www.s2forum.com/forum/showthread.php?t=16997
  • Eriksson
    • Jul 2004
    • 329
    i had to replace this part because i missed the locking screws and broke the plastic.
    Part no for the cylinder, i only use the part thats broaken on my original.
    And the connection plastic part.
    Hope someone have can use the information.
    Cheers Per Eriksson
    Audi S2 Coupe - 92
    My Project
    • Andreas
      • Nov 2005
      • 731
      You will probably have to give 1 irl lesson as well >: !¤%!¤#%%¤&
      Andreas Lundstroem
      A4 STCC Avant -04
      Audi /S/2/ Sedan -94
      prev.
      Audi /S/2/ Coupe -91
        Brilliant guide! Thanks for that!
        • MachineWolf
          • Oct 2010
          • 2
          Thanks!
          Very useful info, really helped!
          Thanks!
            Similar to this one:
            http://12v.org/urs/audi_80_lock_cyli...eplacement.pdf
              Originally posted by UrS4boy
              Awesome Google translate!
              • LHD_Kid
                • May 2006
                • 3696
                How do you remove the steering lock housing once everything is undone?
                its all loose, but no amount of wiggling and tugging gets it to come out...
