i thought i share some info and pictures.
Might be using some strange words so just ask if thers anythingm you dont understand.
First of all remove the following things.
plastic cover underneth the steeringwheel.
ignition connection.
Instrument cluster (Speedo)
Steeringwheel
Steeringwheel plastic covers, both top and bottom.
Light switches, turnsignal etc.
And a black plastic cover see picture below, i had to use som force to remove it.
Black plastic thingie
Some parts removed
Loosen the steering rack bolts to make room for wiggeling the whole cylinder out.
Remove bolt to loosen cylinder (including steering lock)
all out all parts loosened.
Drill a hole for cylinder removal make sure to hit the locking notch, approx 3 mm
Tap out locking pins.
Steeringwheel
Some parts removed
