PAS pump strip down How to
This is a sticky topic.
    How our Power Steering and Power Brake Pump Works
    Originally posted by Rikki Kitto
    Love this Forum most things we need can be found with a search
    If you search a bit harder, I think you would find a post of mine where I put all of Graham's hard work on this into one printable pdf:
    Which is also linked out of this:
    How our Power Steering and Power Brake Pump Works:
    • Rikki Kitto
      • Feb 2010
      • 6276
      Ace work
      • HuwSy
        • Apr 2011
        • 181
        A very old thread to revive but the xplug screw shown in the 1st picture is this the same part number as the s4 with same oring ( 026145541 )? would it be possible to undo this in place without taking the rest apart to replace the oring or would that cause parts inside to move out of place? And what is the part number for the banjo bolt seal next to this 1st xbolt? This is for a '95 S2 ABY. Thanks
        Sent from my Q10 using Tapatalk
        • HuwSy
          • Apr 2011
          • 181
          Ok. For anyone else getting here yes this part does fit our pumps and can be changed in situ with care.
          • slacky
            • Aug 2005
            • 577
            Great thread thanks to all contributors , can I ask is the x plug part readily available from the likes of TPS ?, I'll give them a call when they open, just thought I'd check here....
            Many thanks
            Cab 2.3E
            90q
            URS6
            • HuwSy
              • Apr 2011
              • 181
              It was easily available with the part no above from audi parts when I got one.
              • slacky
                • Aug 2005
                • 577
                Thanks yeh ordered 2 ( 1 spare)
                Cab 2.3E
                90q
                URS6
