PAS pump strip down How to
This is a sticky topic.
  • 91_S2
    • 612
    #31
    Well done Graham
    This is one of those definitive write-ups that people will come back to as the source for working on this part. Nice work.
    • Graham
      • 1622
      #32
      Cheers, its an old post now, but i love playing with hydraulics and thought it would be a good idea to do a how too on this clever little twin pump.
      • s2belgium
        • Aug 2008
        • 98
        • Country: Belgium
        #33
        Very good write-up Graham. Did my pump and it works perfect, costed me 22 euro.
        Thanks a lot!!
        VW Polo G40 '91
        Audi S2 coupe '94
        Audi urS4 sedan '93
        • veneto rs2
          • Jun 2006
          • 1022
          • Country: Veneto
          #34
          Originally posted by Graham
          This will separate the high pressure pump away from the low pressure pump, the galleries in the low pressure side on the left line up with the little hole which feeds the high pressure pump on the right. The galleries feed both high and low pressure parts to the unit.
          Hi everyone.
          I digged out this old and cery well written post from Graham
          My Cabriolet PAS pump it's leaking between the junction of the two cases as per picture on the post above from Graham.
          Pump it's pretty the same as the S2/RS2 ones part # 8G0145165X
          My question it's:
          There's a seal between the two halves and if yes where can I get it?
          Secondly the Orings are common rubber/gum or are them oil resistant ones and any clue where I can get them?
          Thanks in advance.
          Stefano
          http://www.audisportclub.com/
          http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
          • Graham
            • 1622
            #35
            There is a seal kit what you can buy for very cheap-- 035 198 049 A for the aby/3b pump or there is 026 198 049 A for the KV/NG.
            • veneto rs2
              • Jun 2006
              • 1022
              • Country: Veneto
              #36
              Thanks Graham!
              It's this kit including the big oring and the seal for the two halves of the pump then?
              Again thanks for your time!
              Stefano
              • Graham
                • 1622
                #37
                I believe the kit has every seal included.
                Graham
                • veneto rs2
                  • Jun 2006
                  • 1022
                  • Country: Veneto
                  #38
                  Graham
                  Thanks.
                  I was wandering because mine it's leaking between those two pieces.
                  I guess then there's one of the "big" Oring between them ?
                  Becasue I can't properly see if there's one in between....
                  I'm also right assuming that (if there's one) to change it I don't need to take the pulley out and avoid the procedure of press and heating?
                  Sorry if I bother you with this questions mate.....
                  Grazie mille again.
                  Stefano
                  • Mechatron
                    • Nov 2012
                    • 2
                    #39
                    Thanks for the great write up
                    However I still have a problem. After rebuilding my pump using all the information from many sites I have still ended up with a leaking top xplug AAAAARRRG
                    Correct seal fitted from Audi but blew after 5 miles.
                    Someone mentioned a pressure relief valve on the high pressure side ?(any info on this would be handy as it seems a likely cause)
                    Or have I got a distorted x plug? (not seating)
                    I will buy a replacement 026145541 plug and seal to see if it works first before I contaminate the rest of the planet with Pentazine
                    I can see that this is a problem for many Audi owners and would like to find a solution to this irritating problem so that we can all save on G00200
                    Thanks in anticipation
                      its likely the X-plug is just not tight enough, use a cold chisel to tap it tight with a hammer
                      The high pressure relief valve is in the flow control valve piston, which you can see in the picture attached to this post
                      But i doubt that is the problem - try the above
                      • audiman
                        • 4827
                        Easy solution - buy a new one from Audi
                        Tom C - www.rcmr.co.uk
                        Audi UR Quattro
                        Audi 100 C3 2.0 5 cyl 115ps
                        Audi B5 RS4 645ps 911nm
                        • Mechatron
                          • Nov 2012
                          • 2
                          #42
                          Ok so this is how I stopped the flow of earth destroying Pentazine from bubbling out of my x plug
                          1) New plug and seal
                          2) soak seal in Pentazine
                          3) grease seal to stop it snagging when tightened
                          4) PTFE tape the thread on the plug
                          5) Make a tool out of a 1/2 inch drive extention for tightening
                          6) tighten until the car starts turning or you eyes pop out
                          Job done....Just a thought though......how come the bottom xplug never leaks? no grease, no PTFE not very tight ......Strange
                            PAS PS/PB pump DIY thread converted to a pdf
                            Graham: Hope you don't mind but I converted the key parts of your posts above to a single pdf document, suitable for printing off and taking out the garage (for old-schoolers who don't have an iPad for the garage):
                            • Graham
                              • 1622
                              #44
                              No Problem at all, whatever makes life easier--it was over 8 year ago I done this guide.
                              Graham
                              • Rikki Kitto
                                • Feb 2010
                                • 6276
                                Love this Forum most things we need can be found with a search
