My first pictures!!
  • DJones
    • Jun 2005
    • 2020
    Cheers, thrust bearing went and managed to damage the crank!! had the crank re-ground and polished now running an over size thrust bearing. only noticed cuz the cam belt had come forward on the top pulley.... still its all fixed now....... more money!
      #122
      My sympathies
      My sympathies, for a such a PITA I unfortunately know how you must have felt on discovering what’s wrong and then it sinks in that it has to come out, come apart and then go back it.
      Hope in stays in place for ages and behaves itself, good luck with the mapping and enjoy driving it it.
      Kind regards.
      • DJones
        • Jun 2005
        • 2020
        Thanks Dave, i will let you know how the mapping goes. Must admit its pretty quick on the standard ecu, saw off a "55" plate V8 S4 no prob with only 1 bar of boost.
          OMG No!!!!
          Glad to hear it's sorted but what a ****** of a problem. Only ever heard of Greg having the same problem.
          • DJones
            • Jun 2005
            • 2020
            Yes its not common. basically wrong bearing, it was the two piece shell which has the thrust washer built into it as opposed to the six part kit i.e 4 half moon thrusts with the two half shells.
            The two part shell would of been ok but with the new heavy clutch it wore it out in no time. The contact face on the six part kit is twice as wide as the 2 part shell, worth noting if your doing an engine build...
              Are you saying the same as this thread?
              • AndyP
                • 6049
                Was this you?
                http://www.pistonheads.com/gassing/t...p?h=0&t=428049
                • DJones
                  • Jun 2005
                  • 2020
                  http://www.s2forum.com/forum/showthread.php?t=4723
                  Yes bang on wish i had seen that thread. Mine did not spin just wore out in 200 miles due to the new heavy clutch cover plate wanting to push the crank forward.
                  The separate thrust bearing are much wider on the contact face spreading the load more.
                  Stay well clear of the combined when using a none standard clutch.
                  • DJones
                    • Jun 2005
                    • 2020
                    Originally posted by AndyP
                    Sounds like it though mine is LWB and yes it was a women driving with a fella in the passenger seat.
                    S4 cant be running right. didnt even go above the speed limit to show it whos boss. im only running 1 bar of boost on standard injectors with a GT30 and standard ecu say 250 bhp max.. should be 450 when mapped with orange injectors and water injection switched on.
                    I guess this indicates that the twin intercoolers work ok....
                      Oh dear, I read that thread a while back. I'll make it a sticky
                        Are you running a GT30R aka the GT3076 or the smaller GT30?
                        • DJones
                          • Jun 2005
                          • 2020
                          Not sure if im honest! its the gt30/k26 from Turbo Dynamics on RS2 ex manifold. They say good for 450ish... im more intrested in getting the torque correct than the bhp which is i guess what Mr S4 witnessed hence no need for top speed.. she kicks like a mule....
                            Ah it will be the smaller hybrid one then. The 3076 can make 500-525 bhp
                              Yeah I had the same problem on mine when I bought the car, not sure what happened between putting a deposit down and picking the car up but I had to replace the entire short block because the block and crank were beyond repair
                              • DJones
                                • Jun 2005
                                • 2020
                                I very nearly had to replace mine, i was within a thou... of it not being recoverable. South Cererny done a fine job though.
