is that a sprey?
Blacked out headlights... what do you think?
I thought that was the pic at the beginning...!
I don't have any pics of the brackets as I forgot, but I have a couple half wa through refitting...
You can see the rear of the DS2 bulb...
and here, with the rear casing fitted, there is just enough room if you are careful about routing the large wire from the bulb, and make sure you make the brackets to mount the projector fitting as far inside as you can...
Close up of the light fitted on the car, I don't have a picture of them switched on, but they look the same as any others I guess, but they are very well focused, with a definate horizontal line at the top of the light field...
'03 ZX12-R daily hack.... lots of nice bolt ons...Comment
yes, I did spray it, paint is matt finish (not shiny) manifold paint.
Do not use tape to mask off the silver, it wll peel the silver off with the tape afterwards, I used cardboard sheets cut carefully and held over the part to mask, then moved as needed, worked a treat...!Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Bo's step by step guide.Comment
Yes, Bo did his a little differently, although I reckon spraying is easier... also, he blacked the side light reflector and left the ring round the projector silver...
Both versions look good I reckon, and help, especially if you have a black grille surround too...
Nice write up Bo...!Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Last edited by LHD_Kid; 23 January 2007, 23:38.Honda CBR 1100XX Blackbird Turbo....undergoing major changes.....
