Great project, nice interior bits and advanced engineering with that gearbox and I5.
Black s2 Coupe
99 2.8 final edition Cabriolet -
Interesting, I am using the supplied plastic tube.
map-signal with the supplied hose causes spikes and the map-signal goes up and down. Some tuners say that it's because the maxxecu is so quick and reads the pulses in the inlet. But why is the ignition going up and down and Follow the map-signal spikes?
then you add a lot of filter and your fine......
using the original stuff can be better. But just check it for your own safety.
Although only maybe 20-30 cm.
Should I be worried?Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
http://www.garaget.org/?car=52877Comment
the valves are all ok the cam gear does not allow that mutch of play that the would hit the piston. lucky me. if it happens again im going back to stock camgear.Comment
A few small updates. Headlight washer system was not working so found some time to do it new. Now it works just need get new jets as the old ones are not in the best shape. Got also the tensioner for the generator installed. Thanks for the tensioner ultra performance engineering. After a few months the battery died so also got some few things done. Need to put the bumper on and also ordered few things from tradition shop.
Gesendet von meinem EML-L29 mit Tapatalk
sorry ,, why should you not use the plastic hose ? If there is a problem with the plastic hose i dont think maxxecu would sell it with it ?Comment
"Im only mention it based on our experience with the product. Using 60-2 trigger with VR sensor may cause you problem and you may have to solder in a resistor for it. Maxxecu describes it in their manual too."Im only mention it based on our experience with the product. Using 60-2 trigger with VR sensor may cause you problem and you may have to solder in a resistor for it. Maxxecu describes it in their manual too.
regarding the Nuke it's a 50/50. If you want to use it, it's your choice. But now you know it.
In what manual do they describe that ??
is it better than the oe one or?
