Decided to slowly start to remove the tar sound deadening in the to improve sportiness both in terms of weight and feel. Interestingly, there's over 1kg of this stuff under the rear bench alone! Guessing at 20kg for the whole car, pehaps more... get to do some lightweight performance testing with all the interior out too Hoping for 0-60 in 4.xx s
i have removed all isolation in my avant ( exept front floor, there are so much vents under there so the floor would be "rough")
when i sit in the car and slams the door, it sounds like an real racecar should and i still got the carpet and inner doors left ( without isolation inside them) i think i have managed to get ot 15-20kg inside and 30kg under the car, loads of isolation there from previous owner ( or if it´s oem, id dont know)
so there is weight to catch!
ps. the s2 coupe door weight 40kg each complete, a Glassfibre+ "Plexiglass" (english word?) is about 10kg
I've got ALL the underbody sealer and sounded deadening pads frmo my CQ in a bin bag in my garage, i can weight the lot if you are interested Andy - about 30kgs i'd guess
Little tip - heat the sounded deadener pads up with a hair drier until you can only just touch them without burning yourself, then they peel off nicely - then use white spirit to get rid of any sticky residue
Littel tip - heat the sounded deadener pads up with a hair drier until you can only just touch them without burning yourself, then they peel off nicely. then use white spirit to get rid of the stick residue
Safe
