Cq20v RE2400
    #31
    Just spotted something else weird about Hibby's plot - the power & torque lines do NOT cross at 5252rpm... maybe its just my old eyes and this old screen, but ALL plots of bhp and lbft on the same scale should cross at 33,000/(2 * PI).
    Note how the stock 7A has same peak power at wheels and the different shape curves.
    Paul
    • Flat on my back
      • Jan 2007
      • 2449
      Unless the losses are due to the q drive train as compared to only the fwd?
      Carlos.
      • stiglet
        • Aug 2007
        • 1264
        Paul
        Its hard to tell because the scales are all a bit whacky, they don't even start at zero.
        The values seem fairly sensible to me. At low powers the losses become more of a set value loss and NOT a percentage of power. I would expect it to be around 50 bhp.
          #34
          That does have to be factored in for sure - hadn't noticed your plot was FWD. quattro has higher losses for sure...
          • EspenW
            • Apr 2007
            • 1534
            • Country: Norway
            #35
            22% drivetrain loss on FWD is excessive.
            Drivetrain losses are a function of speed (rpm), load (torque) in addition to the static component.
            With increasing power/torque, the loss as a percentage becomes lower, since the static component is unchanged.
            1994 80E Avant
            1986 2L Golf 2 on Alcohol
            • stiglet
              • Aug 2007
              • 1264
              Dug out that chipped ECU if you are still interested?
              • mikeraz1
                • Jun 2008
                • 342
                • Home: Scotland Current: United Kingdom
                #37
                Nice car. Looks much better cared for than my CQ had been before I got it. Enjoyed reading the thred so far as i'm trying to get ideas for tunning my 7A.
                Does any one know how much difference the TSR head make? Just been looking at there web site.
                • stiglet
                  • Aug 2007
                  • 1264
                  Apparently 10-15%, that seems a little optimistic though.
                    A decent porting job and a good valve job can yield about 10%, 15% definately sounds high.
                    • stiglet
                      • Aug 2007
                      • 1264
                      If i'm running 180, which i should be, then thats still 18 bhp which puts me nigh on 200
                      I'd be happy with that.
                        Yogi730 was runnoing 195bhp from a TSR 2.6 in the typ85 90q. Guessing that was ported with a nice cam in there.
                        EDIT:- I think this was a KR 10v tho.
                        • 20Vcqdriver
                          • 829
                          gains
                          If it's an otherwise standard engine it will not make more than 5% and will be at the top end. These heads breath really well as standard. If you start fitting different injectors and larger MAF to get rid of the main restriction then maybe 10% is possible. Only time you'll see a 15% gain is if you increase capacity to 2.5 litre. Steve Cresswell of C&R enterprises (01159785740) knows these engines well, If you want some honest answers he is your man.
                          1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
                          • stiglet
                            • Aug 2007
                            • 1264
                            I have fitted the injectors and a good exhaust, so i would hope to see 10%. I would have expected more from a 2.6 though no?
                              Spoken to Steve before, he knows his VWs and Audis. He helped me when I was struggling with injectors on an old 8V GTI Golf mk.3.
                              A flowed head cannot hurt but 15% is unrealistic IMO, even with cams you might struggle.
                              If you want to stay 20V NA then approach it in the same way you would any other car, capacity increase, head, cams, lighter and balanced internals, port matched and flowed IM, EM and correct flow exhaust, match this to a remap and correct injectors or FPR and that's your lot other than cam timing using a pully or pulleys. You'll not second guess power increases much, I got 2bhp off a flowed head on the Golf and 4bhp off an RS2 IC on the S2, there's always something trying to stick a spanner in the works...
                                Don't forget it's almost all on stroke so it lowers the torque curve down the rev range, getting headline figures up by lots won't happen but compare the torque curves and you'll notice big improvements down low.
