Dest's Ruby Red Avant
  • andyg plym
    • Nov 2006
    • 4646
    lookin fine mate!!!
    knew it would.......
    • irishs2
      • Apr 2009
      • 2455
      Nice and that's a great colour on that avant.
      Eric
      95 S2 Avant under rebuild.
      • europeanme
        • Oct 2005
        • 3817
        what H&R's are you using??...S2 or RS2??....and were they much cheaper from germany even with postage?...
        • dest
          • 4287
          S2 springs with RS2 shocks.
          Yep, much cheaper from Germany! They were £191 inc p&p, shops in the UK were about £230 without p&p, or something like that!!
          • A80Avant
            • 10873
            • Country: Greece
            #35
            i think i have persuaded myself to get some S2 springs as well...going to get them from ebay.de
            • europeanme
              • Oct 2005
              • 3817
              can you get me some as well...:mischeif:
              • dest
                • 4287
                Its well worth it, they are perfect!
                This is a before and after when I put them on my blue one
                • A80Avant
                  • 10873
                  • Country: Greece
                  #38
                  was the back always sitting a bit lower with the springs.?
                  since i have the bilsteins and the rears have 2 grooves i m thinking of using the higher groove to make them sit a bit higher. Seeing this picture now,i see that there is a bit more of a gap on the front than the rear.
                  can you verify that for me?
                  • europeanme
                    • Oct 2005
                    • 3817
                    can I assume that the sellers on ebay.de take paypal only??...
                    I have ditched my credit card.....through lack of use!!..
                    • dest
                      • 4287
                      The back is sitting a little low in that pic cause the back was full of wheels
                      It sits 100% level normally...
                      • A80Avant
                        • 10873
                        • Country: Greece
                        #41
                        oh i see.
                        then i would have to use the same groove. No problem.
                        In any case, is there a way to 'lift' the springs in the front by a 10mm somehow? I mean if i fit a spacer of some sort on the bottom of the front springs, would that create a small lift?so that i can match that to the rear higher groove that is?
                        problem is that the @#^$& that refitted the parking pole in my space failed to tidy the ground so that it is not that high lifted up,and now i fear that 30mm drop will end up skidding the cats or engine cover for sure... grrr
                        and as always those guys are nowhere to be found...
                        • europeanme
                          • Oct 2005
                          • 3817
                          Vas,
                          Who fitted the parking pole??....if it's the council, get them back...if not crank up the angle grinder!!....
                          Sorry for the interuption Dest....
                          • AndersS2
                            • 1364
                            • Home: Norway
                            #43
                            Nice to have you back on the dark side Dest!
                            Anders - S2 Avant Clubsport - 8pots or die!
                            • dest
                              • 4287
                              I wanted to dechrome everything, because Im not a fan of it atall!
                              First I sorted the rear window rubber corners, the same as on my blue one.
                              Every time I see pics of Avants these stick out at me, a pet hate of mine! LOL
                              (Pics obviously nicked from the blue one...)
                              I was toying with the blacked out front grill, but think it looks a bit plain with the rings black too, so wanted a compromise.
                              In the end Ive decided on dark grey, with a black surround (pics to follow, not done that bit yet)
                              I wanted to get new S2 badges, as they are both past their best... this would of brought back the problem of removing all the chrome!
                              So after some thought I had the brainwave to respray them to match the dark grey rings.
                              I am REALLY pleased with how they came out, and cant wait to see it on the grill
                              Before:
                              After:
                              The rear S2 badge will be done to match, and the rear rings in the dark grey too
                              • Acidburn
                                • 13459
                                I've got a couple of badges to do this to, do you think i'd get to see the markings for the rings thru say a white label or would sellotape be good with a decent knife?
