Dest's Ruby Red Avant
That looks better.
Very aggressive.
The Perfectionist
I think the blacked out grill is cool - with black Audi rings I mean... yours is a halfway house.Paul Nugent
Leave the chrome rings, a good balance between the black grill and the elipsoids either side....The Perfectionist
If you are lucky, there is a bit where its started to peel and you can go from there!
Basically, a very sharp knife or blade, lots of patience, and thats about it.
Get an edge started on the outer side of the grill and then it literally peels off and leaves not a single trace.
The pic above showing where it is white, is exactly how it is after the chrome is removed, its not even been wiped!Comment
Thanks for the tips, it gives a really nice result, much better than a quick rub down and a paint as most would do. I think I'll have a go at this on a spare grill I have.
I just hope I've got the patience to see it through to the end as I would imagine this would take a fair bit of time to peel it all off.Last edited by Nuvo; 25 July 2009, 22:24.Comment
Took me an hour or two. Once you get the hang of it you can get the blade worked under big sections and it comes off in quite big bits.
The worst parts are the corners, as it seems "tighter" on those sections.
Also, peel it in the direction I have done in the photo, then its much easier as it comes straight off right up to the inside edge with no troubleComment
What did you do to remove the chrome like that?
