My volcano RS2 Avant
  • EspenW
    • Apr 2007
    • 1534
    • Country: Norway
    #316
    Is E85 available in Belgium yet?
    1994 80E Avant
    1986 2L Golf 2 on Alcohol
    • EspenW
      • Apr 2007
      • 1534
      • Country: Norway
      #317
      Originally posted by Avantus
      I've got 225/45/17 and to hit a real 200 gps (or pbox for that mather) I really do need
      to go that far in the rev range. And I've only got 2-3km/h difference between tacho and gps. No way that I'm hitting real 200 at 7100rpm.
      Strange. My Vagcom logs usually report max rpm in the 7200 range when doing pulls to 200kmh. I let off the gas when the accelerometer flashes at 200kmh. The Garmin GPS that I have used also indicates that I have reached 200kmh, and that is a 1hz unit (higher Hz units will report higher max speed as it is more likely to capture the very peak speed).
      Will do some more testing with both 10hz and 5hz GPS when the car is back on the road (need to fix the rear bumper shell after being hit by a moron (at walking speeds) last fall)
      1994 80E Avant
      • A80Avant
        • 10873
        • Country: Greece
        #318
        Us mortals use plain gasoline Espen! maybe your E85 is also changing your gear ratios!
        • AndyP
          • 6049
          I'll look at some of my G-Tech ( similar to Performance box but accelerometer based not GPS ) and see how it compares.
          We should start a thread for acceleration times, a bit like the FATS database, I know I'm with Espen in thinking that the in gear times are more important than BHP figures.
          • prj
            • Mar 2010
            • 6308
            You know it's like the American horses. It's the Norwegian kilometers!
            • Avantus
              • Sep 2007
              • 941
              • Country: Belgium
              #321
              Originally posted by prj
              Also, I am pretty much done with this ECU - I have accomplished everything I wanted to.
              So whether it is a RS4 maf you want to use, MAF-less tune or whatever else, I can do that at this point.
              Fitting anything bigger than a 3071R will require removal of the airbox though, as it just will not fit.
              I would personally put a GT3076R or GTX3071R on your car, use a compression dropping head gasket and add methanol injection. Then you can start getting closer to Espen's times on here
              Or you could do absolutely nothing at all, and just keep the car looking as OEM as it is, which is better for it's value anyway.
              What reasons are there to chose for one or the other turbo?
              Would a ported K26 wagner be good enough, or is T3 really needed?
              In the end I'm well happy with how it is now, but that bit more is always tempting as many will know
              Anyway, if I pull the head again once, I'll certainly do CR dropping with some head porting to do the lot.
              Main thing is that it stays reliable, and I believe this setup really is that.
              Will be doing a 5000km roadtrip in September towards Corsica so hope it stays that way
              Not that I know of.
              • A80Avant
                • 10873
                • Country: Greece
                #322
                I'd say keep it as is. More power also means faster engine wear no matter how well built. Its just the stresses of the engine that matters.
                If you were absolutely sure if using another turbo, my bet would be the GTX over the GT and perhaps with a bit of cutting here and there you could still get away with it being fitted with the original box. I think someone had done it in the past here on the forum.
                • prj
                  • Mar 2010
                  • 6308
                  GT3071R already requires mutilation, I am not sure at all GTX3071R will fit at all.
                  I personally also think - keep it as is.
                  Nice and reliable setup and it seems quite quick regardless.
                  • A80Avant
                    • 10873
                    • Country: Greece
                    #324
                    The only thing I had to do with the 3071 was to fit a couple of extra washers on the engine mount. Otherwise it fit nicely.
                    Edit: but now that I remember I think the.mechanic had to leave off one of the mount bolts. Very tight indeed
                    • Avantus
                      • Sep 2007
                      • 941
                      • Country: Belgium
                      #325
                      Car was mapped over again by Prj after some small modifications. Plan is to keep
                      it this way as it should be good enough as is, with perfect midrange power.
                      Changes were:
                      - CR dropped to 8.4
                      - 3" Downpipe making it 3" all the way with no cats
                      - extra adjustable wastegatespring to adjust previous maxing out of N75
                      - TFSI coils and EIX8 plugs
                      So nothing major was going to happen with still the same K26/27 turbo, but
                      it was interesting to see what Dmitri could do with his extra knowledge and capabilities now vs 2 years ago. It really is insane what he gets out of these old ECU's, for example the cilinder individual knock detection is great.
                      Anyway it turned out to be a worthwile remap with some adjustments made that
                      changed the character of the engine.
                      - boost is very slightly higher on peak (around 1.85) and it was still on or slight over 1.7bar at 6-6.5k.
                      - gained some turbolag reduction of a few 100rpm over previous setup
                      - The fueling was leaned out a bit as it was too rich. So bringing it back
                      instantly made it feel stronger up top.
                      - Slight timing change at high rpm, but mostly the partial load area had timing pulled big time making it a lot smoother and supple in normal driving. Also fuel economy
                      dropped a lot, a tank that i normally would never had gotten home with is now still not
                      in reserve.
                      Prj once again really took his time for mapping it as nicely as possible, with no knock,
                      and I got more result than what I'd hoped for. The extra grunt from say 5 to 7k is there, but also the general driving feel of the engine makes it much nicer
                      Oh and LC at 1.2bar is sounding insane
                      Power wise it's all guessing, but around 440-450 seemed us plausible. It would need
                      a dyno ofcourse but the buttdyno definately felt a gain
                      In the end big thanks again to Dmitri for the great job!
                      • quattrostyle
                        • Oct 2006
                        • 6229
                        Nice where did you get a wastegatespring in the end?
                        • Avantus
                          • Sep 2007
                          • 941
                          • Country: Belgium
                          #327
                          adjusted the OEM one further down with a longer modified bolt. It only needed a bit extra. At first it was too tight and we were getting boostcreap. Think it's now a small bit lower than you can get with the stock adjustment.
                          • fourwh33ldriv3
                            • Sep 2012
                            • 642
                            • Home: Scotland Current: Germany
                            #328
                            Well this has been a story and a half. What a read, and what a fantastic adventure from start until now, problems come and problems go. I agree with one of the guys in an earlier post that your camera skills are brilliant. We travel around Europe quite a lot in our motor, but planning to take our little cabby out to France for a jaunt soon, nothing as fast paced as yours, but will take in the scenery and sights a little easier.
                            1998 A6 Q (Suzie)
                            2 x B4 80's both 1993 (Heather & Hazel)
                            1995 A4 1.6 (Heather II)
                            1999 A6 Avant 2.4 (Bollie)
                            2001 S6 Avant 4.2 (Rio)
                            1995 80 Cabrio 2.6 (Gracie)
                            2013 Q7 Flooded & gone
                            1995 RS2 2.2 Flooded & gone
                            • Avantus
                              • Sep 2007
                              • 941
                              • Country: Belgium
                              #329
                              thanks!
                              Some more recent ones, also from the 4500km trip to Corsica and south of france (Col Du Turini and so on)
                              Corsica is a MUST do for any roadtrip fan.
                              • quattrostyle
                                • Oct 2006
                                • 6229
                                You have done some nice roadtrips already mate
