On going Project
  • jamie9048
    • 253
    On going Project
    Just finished my brake refit
    S2 now wears 323 disks up front with a pair of Brembo`s salvaged from a Alfa 166 for £70 as opposed to £400+ for some Porche jobs
    fitted with braided HEL lines
    rear calipers rebuilt and refitted
  • LHD_Kid
    • May 2006
    • 3696
    Looking good - might be worth a look at Rusty's budget rear brake upgrade. Would make good use of your refurbed rear calipers:thumbup:
    sent via Tapatalk
      Are those fronts not 314s? Thought the 323s were rear vented
      • jamie9048
        • 253
        defo 323 off a s4
        • bazburn
          • Feb 2010
          • 583
          Who did your brackets?
          • jamie9048
            • 253
            got barrington cnc to cut my templates out have kept the templates if any one wants a copy then had to cut a notch out the caliper to allow the hub bracket to sit in fairly easy to do.
            got some braided hoses done at HEL with banjo fittings
            • bazburn
              • Feb 2010
              • 583
              Thanks...
                Ah, that explains it. They're 321mm off a B5 -
                Sfera è la divisione Server & Hosting premium del gruppo Register.it, parte di team.blue , realtà europea leader nei prodotti digitali per il business. Orig
                Or 320mm off a B7 -
                • jamie9048
                  • 253
                  I`ll get the part number s for the discs I`m 99% they are 323 but its been a few months and my memory is not the best lol
                  the amount of nuts and bolts and parts lost over the last two years has cost me a fortune and made tps pleanty
                  I`d say the calipers fitted has cost £200 (£70 calipers £100 for the cnc work and steel £30ish for pads and sundries) the extra for the lines and paint is £50
                  • jamie9048
                    • 253
                    http://www.ebay.co.uk/itm/Brembo-4po...item35c94a0f19
                      Sure thing, was thrown by the venting on the discs you had, so wanted to understand what you have. Good work on the cheap upgrade though
                      Only thing to be careful of is on those 2 part calipers, they suffer from corrosion and need to be overhauled to keep them working properly. This is the cause of many a braking problem on 993TT equipped cars and the OE RS2 brakes too. HTH
                      • jamie9048
                        • 253
                        Thanks for the advise rusty
                        I've rebuilt them all new seals and cleaned hope they help the stopping
                        I'll try and get as many part numbers and stuff so it may help others I think they look good
