On going Project
Looking good - might be worth a look at Rusty's budget rear brake upgrade. Would make good use of your refurbed rear calipers:thumbup:
sent via TapatalkHonda CBR 1100XX Blackbird Turbo....undergoing major changes.....
Ah, that explains it. They're 321mm off a B5 -
http://www.bremboaftermarket.com/It/...5-1be2445a67de
Or 320mm off a B7 -
http://www.bremboaftermarket.com/It/...6-b29ef1e24f93Last edited by Rusty; 6 July 2013, 14:52.Cheers'en, AndyC
I`ll get the part number s for the discs I`m 99% they are 323 but its been a few months and my memory is not the best lol
the amount of nuts and bolts and parts lost over the last two years has cost me a fortune and made tps pleanty
I`d say the calipers fitted has cost £200 (£70 calipers £100 for the cnc work and steel £30ish for pads and sundries) the extra for the lines and paint is £50Last edited by jamie9048; 6 July 2013, 17:10.
Sure thing, was thrown by the venting on the discs you had, so wanted to understand what you have. Good work on the cheap upgrade though
Only thing to be careful of is on those 2 part calipers, they suffer from corrosion and need to be overhauled to keep them working properly. This is the cause of many a braking problem on 993TT equipped cars and the OE RS2 brakes too. HTHCheers'en, AndyC
