just got my first Audi. F plate Couple Quattro
  • Kieron20V
    • Mar 2008
    • 1505
    #46
    I remember removing all the ABS wiring too, ballache. If i recall correctly I think you need to either connect or ground a yellow wire behind the dash or youll have the ABS light constantly illuminated, which is an MOT failure.
    Just a heads up. Think ive got it written in one of my sketchbooks which wire it was if you need to know for sure.
    Keep it going.
    1994 URS4 Avant RS2+
    • Jaswan
      • Apr 2011
      • 772
      #47
      Cheers Kieron,
      I'm away at the moment for a month or so but I'm just trying to acquire some parts for when I get back
      Jason
      • Jaswan
        • Apr 2011
        • 772
        #48
        Ok, bit of an update.
        Also if a mod thinks this would be better in the projects section could you shift me over please
        Time (and money) have been tight, but I'm off this week so I'm hoping to get a good chunk of work done.
        I have removed the battery tray and bracket for the abs unit etc, then I have removed the front subframe and gearbox.
        Iv got a few other bits to take out before I can give the bay a good seeing to with a wire brush before giving it a lick of paint.
        I aim to do the same with the subframe and wishbones before refitting it with poly bushes and alloy mounts.
        A couple of rust patches
        And I think it's actually split on the driver side, I need to take a closer look
        The engine is still awaiting ARP head bolts and a few new parts before it goes back together
        Excuse my mess haha
        And I was given this from a friend, hopefully it will see some use at some point lol
        That's about it for now, hopefully I'll get more done tomorrow!
        Jase.
        • Jaswan
          • Apr 2011
          • 772
          #49
          Iv given the bay a "very" quick blast of rattle can (Halfords appliance white) paint
          It's by far perfect but the car will be used and abused, also I have used rattle cans so that I can easily add or remove things like brackets etc and just easily paint it back in again.
          Need to get the subframe and wishbones cleaned up and painted then I'll be waiting on solid mounts and poly bushes.
          I'm going to paint the interior in the same paint then I'm intending a dark satin grey for the exterior later on.
          Jason.
          • Jaswan
            • Apr 2011
            • 772
            #50
            anyone know a cheap place to order poly bushes from?
            Jason.
            • Bowie69
              • Nov 2013
              • 2675
              None are really cheap, but floflex, superflex, powerflex can all be bought on ebay or direct, which saves a few quid over most retailers.
              • Jaswan
                • Apr 2011
                • 772
                #52
                Thanks,
                Iv just found Strongflex bushes, has anyone used these?
                They are working out at £70 delivered for 8 of their yellow (harder) wishbone bushes.
                Jase
                • Jaswan
                  • Apr 2011
                  • 772
                  #53
                  I have ordered a few bits, which is exiting,
                  But I'm working away from Monday until December so nothing is going to get done
                  I'm hoping though that when I get back I'll have all the parts to build the engine back up, mount the front subframe and gearbox then actually get the engine bolted to the box so I can make up some engine mounts.
                  I'm hoping at that point things will pick up a bit of pace.
                  I only really need to decide what clutch to use.
                  Jason
                  • Kieron20V
                    • Mar 2008
                    • 1505
                    #54
                    Did you get some gearbox mounts?
                    • Jaswan
                      • Apr 2011
                      • 772
                      #55
                      Hi mate, yea Iv ordered a set
                      • Jaswan
                        • Apr 2011
                        • 772
                        #56
                        mounts are from dominator on the forum
                        Jason
                        • Jaswan
                          • Apr 2011
                          • 772
                          #57
                          things to fit when i get back home (working away at the minute);
                          ARP head studs
                          ARP main bearing studs
                          Scat rods as i wasnt happy with the other ones
                          ARP Rod bolts
                          R36 Coated VW rod/main bearings
                          2x Victor Reinz head gaskets
                          034 motorsports alloy longitudinal flywheel
                          Spec Stage3+ clutch
                          reflashed ECU from United motorsports with turbo map
                          Phaeton 3.2 sump
                          "Strongflex" yellow wishbone bushes
                          Solid subframe mounts
                          01E gearbox mounts
                          Passat VR5 Starter
                          S2 rear subframe
                          Should keep me busy and get things moving in terms of building the car up.
                          i aim to get the subframes and wishbones etc blasted and coated then get it all fitted, box and engine in and some engine brackets fabbed up.
                          • Jaswan
                            • Apr 2011
                            • 772
                            #58
                            need some S2 shafts and prop if anyone has them or is breaking a car?
                            • ake_alex
                              • Aug 2011
                              • 21
                              • Country: Brazil
                              #59
                              Flywheel and Clutch VR6 Longitudinal
                              Hi,
                              Hi, my name is Alex,
                              I have an Audi S2 Sedan, year 1994, I'm in the final stages of the Swap for VR6, I wonder if you can help me, about the Flywheel and Clutch, what do you use in your car? Do you have any other options? what the model of the Clutch ?
                              Thank you very much.
                              Alex Jewtuszenko
                              Audi S2 Saloon 5cly 2.2 20V Turbo + Nitro , 530cv
                              Standart Engine - Turbo upgrade - Fuel injection Upgrade - Exhaust Inox 4''
                              • Jaswan
                                • Apr 2011
                                • 772
                                #60
                                Alex i have replied via PM
