Should the battery not be under the rear seat?
My S2 - 1 of 306
Location of front and rear UrS badges
Originally posted by Nace20 View Postdoes someone know, where it was originaly at the back, dimension from end off bonnet
Positions are as follows:
Front = uppper edge lined up on middle bar grill, badge is 42 mm (or so) from chrome grill trim. (EDIT: S6 turns out to be the same, 42 mm from the lower outside edge of the badge to the edge of the chrome trim (when in the correct vertical location (top edge in middle of the S6 grill height))
Rear = lower left corner 22 mm from left edge of trunk lid (93, 94). Presumably 92 = upper right corner = 22 mm from right edge of trunk lid.
Rear = lower edge 15 to 16 mm above lower edge of trunk lid
Those came from my 93 UrS4 sedan. I just went out and measured the location on my 94 S4 V8 avant and the distance from the edge was 18 mm not 22. The distance from the bottom was slightly less than 15 mm.
There should be some clues in that S2 Sedan pdf that I sent you.
http://forums.quattroworld.com/s4s6/msgs/18657.phtml
Just for fun:
And these (probably from somebody on here):
I know its an avant but at least it shows the left rear corner location.
Originally posted by Nace20 View PostChanged steering wheel today
it feels complete diferent car
and ordered all 3 S2 badges, hope to get them till weekeng
does someone know, where it was originaly at the back, dimension from end off bonnet96 URS6 plus speck saloon
