Should the battery not be under the rear seat?
My S2 - 1 of 306
Yup.
Attached FilesRS2'd 93 UrS4 5 spd sedan
Location of front and rear UrS badges
Because I haven't been lucky enough to see an S2 sedan in person, all I can offer is this info from the UrS4s that I have:
Positions are as follows:
Front = uppper edge lined up on middle bar grill, badge is 42 mm (or so) from chrome grill trim. (EDIT: S6 turns out to be the same, 42 mm from the lower outside edge of the badge to the edge of the chrome trim (when in the correct vertical location (top edge in middle of the S6 grill height))
Rear = lower left corner 22 mm from left edge of trunk lid (93, 94). Presumably 92 = upper right corner = 22 mm from right edge of trunk lid.
Rear = lower edge 15 to 16 mm above lower edge of trunk lid
Those came from my 93 UrS4 sedan. I just went out and measured the location on my 94 S4 V8 avant and the distance from the edge was 18 mm not 22. The distance from the bottom was slightly less than 15 mm.
There should be some clues in that S2 Sedan pdf that I sent you.
Just for fun:
Like this:
And these (probably from somebody on here):
I know its an avant but at least it shows the left rear corner location.
Yes it's surprising the totally different hugely better feel it gives the car. It kind of tells you all cars should have steering wheels as good as the one you have now.
99 2.8 final edition CabrioletComment
