More Power - Stage 2
  • jogi730
    • 2335
    top plate on (note rounded edges)
    Audi 90 quattro (Typ 85)
    20v turbo conversion
    • jogi730
      • 2335
      and sides
        Looks good so far, what sort of design are you going for?
        • jogi730
          • 2335
          throttle body plate
          • jogi730
            • 2335
            modified water manifold
            • jogi730
              • 2335
              Almost complete
              • Billman
                • 4129
                #37
                A very bad one!
                Isnt the plenum tooo big? For what will such a big plenum be good?
                Go Holset or Go RS4
                • jogi730
                  • 2335
                  Originally posted by Billman
                  A very bad one!
                  Proof will only be seen in results. NOT wanting to start off massive debate again, SOME people are of the opinion that dual plenum not needed for turbo cars. And the plenum is to run a big T61 which is a dustbin lid
                  Chris
                  • Corey
                    Banned
                    • Sep 2003
                    • 2793
                    A very bad one!
                    I think considering the effort (and money) that Chris has put into his car I don't believe he will have done something that would harm his hp gains, although the inlet is of a curious design I am quite curious to see the results.
                    Corey
                    01636 822288
                    • Billman
                      • 4129
                      #40
                      A very bad one!
                      AAAAAA, Stop!!! I was kidding!
                      I am sure it will work fine! I am a fan of Dual Plenums
                      Go Holset or Go RS4
                      • Jeffer
                        • 2057
                        Chris
                        2nd that!
                        RS2 Black - stock 315 HP
                        RS2 RS blau - stock 315 HP
                        Sport Quattro - 1005 HP
                        High Octane website
                        • Baldy
                          • 469
                          • Home: Sikkim Current: British Antarctic Territory
                          #42
                          looks like your big power project is progressing nicely there chris.cant wait to see the results
                          Nautic Blue UR-Quattro RS2spec ABY20v kkk26/27 hybrid,Bremsport Brake Kit n some other Gubbins.water injection. Mihnea tuned Management The old Bus
                          0-60 4.9
                          1/4mile 13.5
                          • jogi730
                            • 2335
                            A very bad one!
                            It was explained to me that the main problem with th AAN Im is flow to cylinders 1 and 5.
                            By placing the ramp plate in and moving the position of the TB this equals things out and now flow to all 5 cylinders is equal. Flow tests will be documented later.
                            Cheers.
                            Chris
                            • Billman
                              • 4129
                              #44
                              Cheers.
                              Chris
                              Thats nice! Then you will now for sure if it makes the things better or worse.
                              Nice Project
                              Go Holset or Go RS4
                              • jogi730
                                • 2335
                                More bits for project - New turbo vs old turbo
