Audi S2 Avant - 500 HP Project
  • Faheemo
    • Feb 2005
    • 544
    • Country: South Africa
    More pictures of the inlet ....
    thanks
    S2 Coupe fully built.
    10.9 1/4mile 0-100 in 3.5secs
    Precision 6262 turbo
    The Green Monster
    • prosty
      • Jun 2005
      • 1114
      More pictures of my own made air inlet:
      The "filter shield"
      And the whole engine
      2004 9-5 aero
      2009 Subaru Legacy Diesel
      1994 Toyota Supra Eurospec 6-spd LHD
      3-4 Audis in parts
      • T2Andy
        • 1903
        would like to here the car if poss can you do a small vid cheers
        • prosty
          • Jun 2005
          • 1114
          Sure will try. but I don't have a DV camcorder, will borrow my friends camera for better resolution, the one in my cell is not that impressive.
          2004 9-5 aero
          3-4 Audis in parts
          • prosty
            • Jun 2005
            • 1114
            Unfortunately Eriksson is such a "toffel" as we say in swedish, so he rather spends time with his GF other than helping me getting a decent in-car Video of my Avant.
            So here it is. Filmed last night, 18 Degrees celsius.
            Full interiour, full tank of gas. 1.4 bar boost, the turbo starts to surge after that, going to port the head this winter and hopefully be able to run 2.2 bar with racefuel and a low 11 second time on the dragstrip. Maybe I'll take the car to the dragstrip this weekend just to see what time I get. I've gotten a lot sharper in driving the car lately.
            Pulling too long on 4'th gear as you can see, when I shift into 5'th the cars pulls harder the few first seconds. So the 100-200 km/h could be improved a lot. However it was pitch black and a lot of cars in the vincinity so I had to concentrate on that also
            2004 9-5 aero
            3-4 Audis in parts
            • s2dude
              • Nov 2005
              • 1631
              http://www.rackeltrim.se/Adolf/1.4BAR_test.3gp
              Cars looking good!!
              Though what is with the air filter in picture 2??
              If it has crushed like that just from runing the car (and not deliberately so it fits in smaller space etc) it is restricting the cars breathing quite badly and needs to be changed for soemthing Bigger and better flowing
              Good Work though
              • prosty
                • Jun 2005
                • 1114
                I've just mistreated the filter, the intake surface is still the same size so I don't think it will affect the car that much actually?
                2004 9-5 aero
                3-4 Audis in parts
                • Billman
                  • 4129
                  #23
                  What turbine exducer diameter do you have?
                  Would a 13ccm housing stop the surging? At what RPM does it surge?
                  Go Holset or Go RS4
                  • prosty
                    • Jun 2005
                    • 1114
                    at about 4500-5000 rpm
                    I will port the head this winter, I'm pretty sure that will solve the issue.
                    2004 9-5 aero
                    3-4 Audis in parts
                    • s2dude
                      • Nov 2005
                      • 1631
                      If the induction of the turbo is causing this filter crush then it will be reducing the amount of potential air to reach the engine and causing inefficiencies in the system....
                      a better/bigger filter will make a difference Im sure.....
                      • prosty
                        • Jun 2005
                        • 1114
                        When I used a bigger filter I got too lean mixture, will fix that this winter with new map for the ported head. But I've straighten out the filter a bit today, and cleaned it
                        2004 9-5 aero
                        3-4 Audis in parts
                        • sorens2
                          • 241
                          • Country: Denmark
                          #27
                          Here is mine @ 1.5 bar
                          Søren S2
                          Audi RS4 LO550
                          BTG 8:08
                          www.fredslunds.dk
                          • prosty
                            • Jun 2005
                            • 1114
                            Yes I've seen that video. really fast. mine isn't 500 hp like I've stated earlier, now it's more like 400 + an avant. We found out that the head was the limit for this turbo, so after it's been ported this winter, then I can possibly get 500+
                            2004 9-5 aero
                            3-4 Audis in parts
                            • Tommy200rs
                              • 285
                              #29
                              Prosty, did you participate in Mantorp this year :
                              - some fast beasts were seen there!
                              • prosty
                                • Jun 2005
                                • 1114
                                Hi. No unfortunately not. I'm hoping to get there in 2007. the car ran to bad this year. going to the track on saturday to try and getting a better time.
                                2004 9-5 aero
                                3-4 Audis in parts
