Audi S2 Avant - 500 HP Project
  • prosty
    • Jun 2005
    • 1114
    My friend Andreas (member on this forum BTW) followed me to our garage and he took some pictures of the upgrades that I've fitted so far this year:
    Enjoy!
    2004 9-5 aero
    2009 Subaru Legacy Diesel
    1994 Toyota Supra Eurospec 6-spd LHD
    3-4 Audis in parts
    • prosty
      • Jun 2005
      • 1114
      Those recaros are truly mint condition. Can't believe how good they look.
      2004 9-5 aero
      3-4 Audis in parts
      • prosty
        • Jun 2005
        • 1114
        Connected the cables to the recaros, the head is assembled and prepared, recieving it with the new cams on tuesday or wednesday, then the fitting begins
        2004 9-5 aero
        3-4 Audis in parts
          How far off being finished is it now?
          • prosty
            • Jun 2005
            • 1114
            Putting the valves , spring and retainers into the head.
            Putting the head on the block ,torque it down, measure all the oil + water lines for the turbo. Assemble the engine to the car, connect all connectors, lines + hoses and so on, weld a new front engine mount (034 type) to the crossover. Add all fluids. Charge the battery and connect it :-) Turn the key and hope that the car doesn't burn up.
            Will probably go with a VAG Com diagnostic first considering almost every connector has been disconnected this Winter.
            About a weeks work if everything proceeds as planned. Depends on my health, have some sort of virus in the system now so I'm not feeling all to well. Otherwise I would've done it alot faster.. Last time it took me 48 hrs from when I assembled the block and turned the key and fired up the engine.. (+ I had a day job between 09-18) But I don't want to make any mistakes now.. No rush, the winter is still here so there's plenty of time
            2004 9-5 aero
            3-4 Audis in parts
              Yeah take your time. It took me and my dad a few hours to find the right place for all of the connectors after the engine had been taken out.
              • prosty
                • Jun 2005
                • 1114
                Yeah, i've come to the conclusion that you only can misfit 2 or 3 connectors.
                Will replace all the vaccuum lines too, the ones that are on the car now have seen their time.. Only have power steering fluid and glycol (???) left on the purchasing list from VAG. Feels like I've spent a fortune there, the tranny rebuild cost £375 just in parts. And that was far from beeing the biggest expense..
                Still haven't received the head nor the cams, the cams seem to be somewhere between Finland and Sweden..
                2004 9-5 aero
                3-4 Audis in parts
                • prosty
                  • Jun 2005
                  • 1114
                  This years most interesting upgrade, interesting to see how much this does.
                  Tonight I'm putting in the engine, another S2 clutch change came in between, yesterday erixon took the tranny down so I can work on my own car for a change
                  Still haven't received the cams though, but the head is fitted on the engine. So I'll just put the cams on later.
                  2004 9-5 aero
                  3-4 Audis in parts
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Prosty looks very good, love the "Adolf" badge.
                    Where did you get the inlet pipe made up that runs to the throttle body??
                    Chef
                    • prosty
                      • Jun 2005
                      • 1114
                      terrybullwon: I made it myself , its stainless steel. I can make one for you , about £100-110 + postage. And I'll make it shine just like on the picture
                      It looks awesome. That is the first one I've made (made a few more now), so the welds are not 100% , but on the new ones I've tig welded, so they look much better now than the one on the picture above. Can make with different flanges for BOV and so on. I had to make one since I'm going with 2 BOV's on the cold side of the IC.
                      The ADOLF badge is from CADDY and GOLF
                      They really laughed @ the VAG dealer when I said what I was going to do with both those badges
                      2004 9-5 aero
                      3-4 Audis in parts
                      • Ross
                        • Aug 2005
                        • 3399
                        Are you using any "exotic" parts in the head? Or all stock other than cams? (like, springs + retainers)
                        Will be interested to see how the porting has improved things too, as I'm considering some port matching if I can justify the cost...
                        • prosty
                          • Jun 2005
                          • 1114
                          Hello, I'm using stock internals in the head. This is good for up to 600 hp. After that you need to improve them some. Bought 20 new lifters for this year. They were a bit worn the ones that I had...
                          Will be difficult saying how much this will affect the car since I'm upgrading turbo, cams and the head at the same time..
                          The cost for restoring a head and porting + machine job for the valves is £890 (In Sweden).
                          2004 9-5 aero
                          3-4 Audis in parts
                          • prosty
                            • Jun 2005
                            • 1114
                            20 minutes of work and it's there. The 034 engine mounts had a perfect fit. The engine WILL NOT BUDGE when I tried to move it.. And ppl call me the little hulk.. Even though I always look like Bruce Banner.
                            2004 9-5 aero
                            3-4 Audis in parts
                            • Jay
                              • Jul 2004
                              • 599
                              #104
                              Bruce Banner, whos he?? I thought it was David Banner that turned green
                              Jay
                              • Jay
                                • Jul 2004
                                • 599
                                #105
                                Jay
